VideoHelp.com Forum
Results 1 to 9 of 9
  1. Member Fary4u's Avatar
    Hi
    i'm just trying to work wd Adobe Premiere Pro CS3 with following file extension MXF
    i've got SxS Pro Memory Card, file extension is MXF need to export Premier Pro CS3 software ?
    and export finaly into DVD
    i'm having problem to access mxf file how can i compose my movie ?
    Fary
  2. pp cs3 should work with it ok. it's most likely sony xdcam.
  3. Member Fary4u's Avatar
    thanks 4 u kindly reply : )
    any explanation plz if possible ?
    Fary
  4. open pp3. use file/import. navigate to the card. open the contents folder. open the video folder, open the mxf file. do the same for the audio 00 file, but it's in the contents/audio folder.
  5. Member edDV's Avatar
    What is the source of the file?
    MXF is a pro minefield more linked to Panasonic DVCPro than Sony's XDCAM but it could be that too.
    This older wiki entry describes some of the first level issues. Your job if you accept it is to trace the origin of this file. We can't do that for you. Which camcorder produced the file? Or was it a Firestore drive?
    http://en.wikipedia.org/wiki/MXF
    The story gets more complicated as you dig in.
    PS: If I'm re-reading your original post correctly, you have an SxS card from an XDCAM-EX camcorder?
    http://www.kiva.org/about
  6. Member edDV's Avatar
    OK, I can give you more background but not a solution. I've only worked with Panasonic MXF, not yet XDCAM-EX.
    http://digitalcontentproducer.com/ca...ex/index3.html
    http://www.adobe.com/products/premie...kflowguide.pdf
    Good luck with that.
  7. wow learn something every day. i never noticed the pp "import folder" button in the file/import dialog. crap, i've always selected multiple files with the shift or control keys.
  8. Member Fary4u's Avatar
    Thanks 4 ur kindly reply
    but when i create DVD the quality is fine like ( HD ) only when it's playing it's play very slow : (
    what's the best solutions for this ?
  9. get and install mediainfo. put it in text mode. open your source mxf file with it. copy the complete text output and paste it here so we can see the specs. do the same with the output mpeg-2.
  1. Adobe Premiere Pro CS3 & Vegas Pro help
    By KS89 in forum Editing
    Last Post: 8th Sep 2009, 22:52
  2. Adobe Premiere pro CS3 to DVD using MP4
    By Fary4u in forum Video Conversion
    Last Post: 3rd Aug 2009, 09:22
  3. Adobe Premiere pro CS3 to DVD using MP4
    Last Post: 13th Jul 2009, 12:13
  4. Adobe Premiere Pro CS3 ERROR =/
    By ervand in forum Editing
    Last Post: 11th Nov 2008, 22:28
