I usually test images created on the computer with TMediaTheatre.
Here is what I found:
1) 2-3 m2ts files combined with TsMuxer -->multiavchd---> image created in ImgBurn (UDF 2.5)--> mounted in DAEMON ---> success in TMT
2) 56 m2ts files (about 4.2 GB) combined into ONE HONKING FILE-->multiavchd---> ---> image created in ImgBurn (UDF 2.5) ---> failure in TMT
In both cases I can play content from a folder using TMT - it goes like a charm.
When I use only tsmuxer to create Avchd structure I get stuck in the same place.
What's wrong? ImgBurn? Do I need to select some additional settings I don't know about?
Anyone?
TMediaTheatre wont play mounted avchd images all the time,just load the avchd folder instead to test,when you burn the files then TMediaTheatre will play.
Ben Johnson-I didnt take any stereos!
Actually, you got this one right.
TMT doesn't play images and dvds made with Mulitiavchd, but my Panasonic DMP BD35 does!
Just so all of you guys know.
Change FPS of a video track (M2TS) with multiAVCHD
By TheUnknown in forum Authoring (Blu-ray)Replies: 3Last Post: 5th May 2011, 09:41 -
Help with multiple .m2ts files to one .m2ts
By neworldman in forum Blu-ray RippingReplies: 7Last Post: 17th Mar 2010, 19:39 -
Playing multiple m2ts files on PS3 from a DVD
By dieselgg in forum Authoring (Blu-ray)Replies: 2Last Post: 20th Jun 2009, 09:47 -
M2ts files to DVD
By tmgrood in forum Blu-ray RippingReplies: 3Last Post: 12th Mar 2009, 05:40
Statistics
Newest guides
Latest tool updates
New media comments
