I've recently upgraded to the CS4 Master collection, and had a new machine to go with it. I have as few codecs on as i need in order to keep any issues to a minimum, and also as little software as possible.
I'm wanting to use the Adobe Media Encoder to convert my MTS AVCHD footage to a lossless intermediate. I dont normally use an intermediate as my own footage is always HDV which is dealt with fine by all of the suite, however this is someone elses footage. The files load into Media Encoder fine, however even tho i've installed the codec, it's not showing as an option for any containers. Anyone else use this and know of how to fix it?
If not, anyone able to recomend which of the intermediates available in Media Encoder are good lossless codecs (i would install Huffy only i fear the issue would be the same as Lagarith).
Cheers for the advice...and my loathing for AVCHD is getting more and more by the day!
Results 1 to 9 of 9
I'll try updating. Cheers.
For future reference would you recommend any of the other Codecs available in AME CS4, specifically as an intermediate?
I normally just work with the HDV footage and then encode as a High Quality H.264 file Fpr my export format.
I would also look at the Avid HD intermediate codec (DNxHD), which is free and very good. Works like a free version of Cineform, without the need for NeoScene.
See here for details and links : http://forum.videohelp.com/topic369594.html
I'm really interested in that DNxHD codec. Had a look into it a bit and found its download page:
http://avid.custkb.com/avid/app/self...p?DocId=263545
Although the PC Zip file seems to be corrupted. Could anyone else please confirm this? (i downloaded it twice, on different machines)
That is the same download link I used two weeks ago without issue, but today it is corrupt. The version I downloaded was 1.8, so it appears the update to version 2 is the problem. I have attached the archive for 1.8 that I downloaded, and which does work
avidcodecsle_1.8pc.zip
Cheers for that, I'll have an experiment with that this morning and see how it goes.
Avid have fixed the link to version 2 of the quicktime DNxHD codecs for Windows. If you want them they are here : http://avid.custkb.com/avid/app/self...p?DocId=263545
Adobe Media Encoder
By kerb in forum Video ConversionReplies: 4Last Post: 27th Dec 2011, 20:15 -
Adobe Media Encoder stops encoding for no reason
By moogleii in forum EditingReplies: 2Last Post: 10th Dec 2009, 11:25 -
crop and resize with adobe media encoder (at once)
By v1p0n3 in forum EditingReplies: 16Last Post: 9th Dec 2009, 15:25 -
Adobe Media Encoder CS4 resizing
By dedek74 in forum Video ConversionReplies: 4Last Post: 22nd Aug 2009, 14:37 -
Adobe Premiere 1.5: Adobe Media Encoder: Frame size and scaling?
By vid83 in forum EditingReplies: 2Last Post: 30th Nov 2008, 03:17
