My Pioneer DVR-530H has been acting up lately.
After recording to the HDD, it cannot copy to a DVD-R disc, its says "Copy err" and it sounds like the discs cant get up to speed.
However it works when i use a DVD-RW.
I've tried other brands of DVD-Rs with no luck.
Is there any technical/mechanical difference to how it records onto a R/RW? I'm a bit dumbstruck over this.
Any advice to get this thing working?
Hope that someone can help.
Regards,
Henrik, Copenhagen
This is common and due to the burner aging. The reason RW works is because its spinning at a slower speed and using an old dye formula, most DVD-R media available today is much faster 16x-rated which is the first thing to "break" when burners start wearing out. In later Pioneers, failure with 16x DVD-R is mechanical: the disc clamp loses its grip at higher speeds. With older models like your 530, the laser/firmware loses compatibility with newer forms of 16x media first, then 8x, then RW. See if you can purchase some 8x Taiyo Yuden (TY) DVD-R media to test on your failing 530. This may work better than the 16x, but more likely will also fail. Still, its worth a try if it will let you burn a hundred more discs before the drive finally dies for good. If 8x DVD-R does not work, the burner needs to be replaced: nothing else will cure this behavior on a Pioneer 530.
It is possible with some effort to replace the burner in a 530 yourself, at low cost. You need to search the eBay site in your country for an old Pioneer DVR-109 or DVR-AO9 pc burner that still works properly. When you get it, you need to remove the burner from your 530, open its case, and exchange its custom controller board with the one in your replacement burner before installing the replacement in your 530. Complete details on this procedure can be found in the thread:
http://forum.videohelp.com/topic353746.html
I tried recording in Optium-mode and that works.
It burns on playback speed, so it takes longer, but atleast im getting the content off the HDD.
Thanks for your help.
HDD Data Recovery - from Pioneer DVR-530H-S failed hard drive
By fortisMilvus in forum DVD & Blu-ray RecordersReplies: 13Last Post: 19th Nov 2011, 05:02 -
Pioneer DVR-530H. Unable to delete or edit some titles.
By Baloooo in forum DVD & Blu-ray RecordersReplies: 7Last Post: 20th Mar 2011, 00:15 -
Pioneer DVR-530H Question (Please help)
By Corey_Futurama in forum DVD & Blu-ray RecordersReplies: 7Last Post: 10th Jul 2010, 07:28 -
DVD writer exchange for my Pioneer DVR-530H
By J.J.F in forum Newbie / General discussionsReplies: 1Last Post: 20th Jan 2008, 09:40 -
DVR-530H not playing DVD-R/RW
By robsic in forum DVD & Blu-ray RecordersReplies: 1Last Post: 4th Sep 2007, 13:09
Statistics
Newest guides
Latest tool updates
New media comments
