I get an error message when tryung to install:
The folder path 'VOB2MPG PRO' contains an invalid character
Can some one help me out please?
Thanks,
Jack
Results 1 to 11 of 11
Thread: will not install
What folder are you installing into?
I have Windows XP Pro. I just clicked on the setup.exe file or the VOB2MPG PRO Setup.msi file. If I need to specify a folder how do I do that. My hard drive is I: not C:
You get the option of where to install during the installation process... Replace the C with an I giving I:\VOB2MPG PRO
I don't get that far. As soon as I click on the file the error pops up.
If I'm not mistaken I believe the setup.exe and the VOB2MPG PRO setup.msi could be corrupted files.
What is their path?
What you can do is run at a command prompt:
e.g:Code:msiexec /i "path to msi file" /l* "path to a log file"
Code:msiexec /i "i:\VOB2MPG PRO Setup.msi" /l* "v2m.log"
and then attach the log file here...SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
I still get the same error.
Tried different things but to no avail.
I uninstalled 5 other programs and will try more, there may me a conflict somewhere.
What netframework should i install?
By boblee in forum Newbie / General discussionsReplies: 3Last Post: 18th May 2011, 09:51 -
How to: install MCTemporalDenoise
By quandore in forum Blu-ray RippingReplies: 15Last Post: 18th Oct 2010, 09:51 -
Uninstall/Install over or Install new versions separately?
By MindF in forum ComputerReplies: 2Last Post: 5th Apr 2008, 13:43 -
Use without an install
By raschko in forum Newbie / General discussionsReplies: 0Last Post: 9th Aug 2007, 16:37 -
install
By Brasilman in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 29th May 2007, 09:17
