VideoHelp.com Forum
Thread: Clown_BD
    Hiya,
    Using this for my BD rips, outputting to M2TS s 7MC plays it natively.
    However, i'm confused by the audio selections. I want only the main movie and 2 audio tracks (best available and 2.0). When ripping The Incredible Hulk, I have the audio tracks on the left hand pane, as well as audio tracks in the right hand mini pane.
    I've tried it once, selecting DTS MA on the left, and AC3 and DTS MA on the right. When playing on my laptop I don't have any audio.
    So I guess I need to select AC3 in the left hand pane as well. So what is the right hand audio selection all about?
    What are you playing with? Try MPC-HC! and you should be able to choose audio track. You can also get ac3 filter and haali media splitter but mpc-hc should be able to handle everything.
    I'm using Media Center on Windows 7 x86. This was after a clean install with no additional software/codecs installed.
    I thought Windows 7 can play m2ts files without additional 'help', but will try again and see what happens.
  1. Replies: 0
    Last Post: 3rd Jan 2011, 23:35
  2. Clown_BD, Avatar and Sound out of Sync
    By KiwiOca in forum Blu-ray Ripping
    Last Post: 17th Jun 2010, 21:50
  3. I don't get Clown_BD?
    By David9799 in forum Blu-ray Ripping
    Last Post: 4th Oct 2009, 08:28
