VideoHelp.com Forum
Results 1 to 9 of 9
    Can someone tell me why I could not encode the file, It is captured via watchtv as a dvr-ms, using an ATI HDtv wonder pci, I'm using the latest version of svcd2dvd. I'm also attaching a link to the file. Thanks.
    http://www.teradepot.com/8cl9h4knldf...PM.dvr-ms.html
  2. Member ChrissyBoy's Avatar
    Works fine here... are you getting an error?
  3. Hi Chris,
    I tried it too and though it seems to process fine, I get a black video. I was going to try the avs option but haven't had time as yet. No error produced.
    Dwight
    "A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
    - Herm Albright
    www.martialconcepts.com
  4. Member ChrissyBoy's Avatar
  5. I never doubted your success.
    I also have processed it successfully. Chalk my error up to PC needing a reboot.
    Dwight
    - Herm Albright
  6. Member ChrissyBoy's Avatar
    Dwight - I know! Perhaps dalego can expand on his issue?
    Hi guys, sorry for the late reply, the problem i'm getting is the video shows a black screen during playback but the audio sound good, the video format also goes to 4:3 format although its blank, I'm just using the default settings of svcd2dvd, might be my own computer is giving me the problems cus you guys think its ok. the only thing I dont get is if i convert the dvr-ms to ts then encode it under svcd2dvd, everything comes out perfect.
  8. Member ChrissyBoy's Avatar
    Are you playing the DVD on your computer or DVD Player/TV?
    I'm playing it on a computer, I'm using cyberlink powerdvd, tried using VLC, it would play the movie but keeps on freezing up.
  1. Pioneer DVR-520H: seeking advice for DVR-107-XA drive replacement.
    By donglejack in forum DVD & Blu-ray Recorders
    Last Post: 12th Feb 2012, 08:24
  2. Pioneer DVR-520h or DVR-220 or DVR-225 replacement DVD-RW drive
    By psymaster in forum Newbie / General discussions
    Last Post: 31st Oct 2009, 19:48
  3. Pioneer DVR-520h or DVR-220 or DVR-225 replacement DVD-RW drive
    By psymaster in forum Latest Video News
    Last Post: 31st Oct 2009, 17:26
  4. Replies: 1
    Last Post: 13th May 2008, 07:20
  5. Pioneer DVR-550H-s: transferring video from laptop to DVR's Hard drive
    By anandmahey in forum DVD & Blu-ray Recorders
    Last Post: 10th Feb 2008, 08:13
