8mm and Super 8 films can have lots of color issues when restoring and transferring to the digital domain. I'm at the point in my learning curve where I have discovered that the MSU Old Color Restoration Filter (v 0.9) when used in virtualdubmod can find fairly accurate colors which can then be worked with.
My only problem with this filter is that areas in the original with any luminance become VERY white with a loss of details. Here's an example with credit to themaster1 :
http://img185.imageshack.us/img185/5454/image2vv3.jpg
Although I can use Gradation Curves to lessen the luminance in the top range, the details are still lost.
Can anyone offer any help or suggestions ?![]()
Results 1 to 15 of 15
I am sure you will get a professional answer on here, but perhaps toying with the gamma (some filter must exist for this) might help you out a bit
PS: thank you for the heads up on the old color filter
This bring us back to this thread
color mill may help you to work on the levels (dark/middle/light)TheMaster Rules ;)
Use AviSynth to open your source then add ConvertToRGB(matrix="PC.601"). That will give you more head (and tail) room. You might have to follow with Levels afterwards to fix the levels (blacks at RGB=0, whites at RGB=255).
Word of warning -- ColorMill has created interlacing damage on some videos I've used it on. It's very random, I don't know what causes it just yet!
Answers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video
Interlaced YV12 sources? VirtualDub doesn't handle interlaced YV12 properly. It treats it as progressive, thereby blending the chroma channels of the two fields. The workaround for this is to open your YV12 source (MPEG 1/2/4, PAL DV) with AviSynth and convert to YUY2 or RGB with the interlaced flag set to true:Originally Posted by lordsmurf
Of course, you'll need to follow that with interlace aware filters or techniques in VirtualDub.Code:WhateverSource("some YV12 source") ConvertToYUY2(interlaced=true)
Nope, not YV12.
It was an I-frame only high bitrate MPEG-2 opened with MPEG2.vdplugin in VirtualDub 1.8
I'm not convinced ColorMill is an interlace-aware filter!Answers to Common Video Questions:
That would be YV12. The MPEG decoder decodes as interlaced YV12, then VirtualDub converts to RGB incorrectly. Here's are some samples with VirtualDubMod, VirtualDubMPEG2, and VirtualDub. VirtualDub handles the interlaced MPG data incorrectly:Originally Posted by lordsmurf
Well, sumbitch...
I'll need to re-add the MPEG2 and MOD to the system, if that's the case.
What I observed I cannot explain. It was not field order issues, but there was some sort of oddity going on, move clearly viewed during a pan.
What has thrown me, however, is the fact that it was random. Two other projects looked fine, only the one was all fubar.Answers to Common Video Questions:
I forgot to mention those screen caps were at 4x enlargement. The red lines are one pixel thick in the originals.
And, as mentioned, you can use AviSynth along with Virtualdub to get around the problem.
Is there a way this can be repaired? I have a video here that had its interlacing messed up by the aforementioned VirtualDub (MPEG-2 source) YV12>RGB conversion, something cleaned up by Colormill.
What has been done to the video? You opened the MPEG 2 video in VirtualDub -- and then what? Some filtering or conversions might leave the video still fixable. Can you provide a short sample?
Well, I ran the first one through Restream, and it was actually fine after reversing interlace. I'm going to see if I run across anything that Restream won't handle correctly. It's not as bad as your 1.9.2 image above.
The footage is so degraded that it didn't look like a simple reversal, but that may be all that happened.
I'll keep you informed...
Thanks.
That video was chosen as a very bad case example. Most real world video with the problem won't look as bad.Originally Posted by lordsmurf
It's not a field reversal. It's a case of interlaced chroma channels being handled as progressive chroma channels. In progressive YV12 the first line of chroma is applied to scanlines 0 and 1 of the luma channel, the second line of chroma is applied to scanlines 2 and 3, etc. In interlaced YV12 the first line of chroma is applied to scanlines 0 and 2, the second line of chroma is applied to lines 1 and 3, etc. That is, the chroma is interlaced as well as the luma.Originally Posted by lordsmurf
Well, mine is appearing to be a simple reversal --- that's what's so confusing about this.
MSU Old Color Restoration alternative?
By magillagorilla in forum RestorationReplies: 55Last Post: 30th Jul 2011, 12:30 -
Creating new MSU VirtualDub filter.
By diablo23q in forum ProgrammingReplies: 5Last Post: 15th May 2011, 15:04 -
Telecine Machine for 8mm film super 8 film transfer to dvd
By igotregister in forum CapturingReplies: 5Last Post: 2nd Feb 2009, 15:50 -
Using MSU Smart Deblocking Filter...
By AshleyQuick in forum Newbie / General discussionsReplies: 4Last Post: 28th Apr 2008, 20:17 -
Top quality professional transfer of 8mm and Super 8mm film
By cosmichippo in forum Video ConversionReplies: 75Last Post: 25th Jul 2007, 21:28
