Hello all,
Am new to this form and my hi to all people out there.
I have a question regarding HD file format. I have a ScreenPlay HD media player and in the I have a MKV file which is almost 5 GB and is 1080*1920. I would like to watch this in my sony bravia HD TV but the TV is not supporting the file format. Now I would like to know, which file format my TV will support? If there any convertor for the same purpose? Thank you very much for the answers in advance!
Shrirama
Thread: Sony Bravia HD file format
I found this:
http://www.iomega.com/support/manual...d/en/main.html
That is the on-line manual for the ScreenPlay Pro HD Multimedia Drive. Unfortunately they seem very elusive on information. Here are some interesting things I did find:
1.) It appears to only support 1080i output (no 1080p in other words). 720p output is supported as well as 480i/480p
2.) I find the follow comment very "telling": "MKV files encoded with MPEG-4 codecs are supported natively. MKV files encoded with H264 codecs are supported using Transcode Server Software"
That second point seems to indicate that H.264 is not truly supported. Bummer.
Also I could find no information on what resolutions are supported ... sure it tells you want it can output ... but although it covers the file "formats" it can handle it doesn't give any actual resolution numbers. Weird.
Thanks a lot John for quick reply.
Sorry to tell that am not aware of the differences between 1080i and 1080p format
.. How does that make any difference? whats does Transcode Server Software means?
Thanks again!
Shrirama
Google is your Friend
Most Sony Bravia HDTV sets play no video files* whatsoever. If you have one that does, it would be spelled out in the manual. It would play from a USB flash drive.
* some display jpg stills or play mp3 audio files from USB.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
I know this get's asked alot, but best playback on my Sony Bravia
By kbphoto615 in forum Video ConversionReplies: 3Last Post: 23rd Oct 2011, 01:39 -
Converting video to MPEG2 for Sony Bravia TV
By Teufelshunde in forum Video ConversionReplies: 7Last Post: 6th Jan 2011, 10:39 -
HP Pavilion dm1 and Sony Bravia
By christinaki19 in forum ComputerReplies: 6Last Post: 27th Nov 2010, 16:04 -
Sony Bravia 40" BX400 - USB Video Format issue
By dreamcast in forum Video ConversionReplies: 4Last Post: 16th Oct 2010, 08:49 -
question about sony bravia usb connection
By ivyer in forum DVB / HDTVReplies: 3Last Post: 1st Nov 2009, 04:53
