VideoHelp.com Forum
    I have 4 computers with WinXP and MPC. All play clips fine except 1t doesn't display frame rate. Just stays at 0:00 but will display buffer and bitrate.
    Any suggestions will be appreciated.
    WIth all kinds of video?
    Or try just use mpc-hc and see if it works better.
    Happens with all video formats and mpc-hc.
    I've seen this problem on a friends computer awhile back but he never did resolve the problem.
    BTW: This is a fresh install of WinXP on a clean HDD.
    Which frame rate are you talking about? The one that shows when you select File -> Properties? The one that shows when you enable View -> Statistics? The one that shows when you select View -> Display Stats? The latter two get the frame rate from the video renderer (graphics card drivers). If the renderer isn't returning that information you'll get zero. The one from File -> Properties comes from the file header. Some video files have variable frame rates and the value in the header may not be set.
    jagabo, I think you're on to something.
    It's enaable View -> Statistics (real time frame rate).
    I uninstalled the video driver and it works. Reinstalled the driver and no luck.
    Select View -> Options -> Playback -> Output. Then try the different DirectShow Video devices. You have to Apply, exit MHC (or MPCHC), and restart it for the change to take effect.
    Hey jagabo.... thank you very much.
    The Playback -> Output for Direct Show Video was set to 'Overlay Mixer'. Changing it to 'System Default' solved the problem.
    Life is good again!
  1. audio bit rate showing in video
    By soulman1015 in forum Newbie / General discussions
    Last Post: 20th Nov 2009, 10:44
  2. No video showing in MPC?
    By mikehende in forum Newbie / General discussions
    Last Post: 20th Mar 2009, 13:22
  3. warning message in first frame of avi's played in MPC
    By majax79 in forum Software Playing
    Last Post: 18th Jan 2008, 14:25
  4. Bit Rate And Frame Rate
    By bharathi_n_r in forum Video Conversion
    Last Post: 30th Nov 2007, 05:48
  5. Frame rate conversion by changing frame count
    By asmaa in forum Video Conversion
    Last Post: 1st Aug 2007, 10:15
