VideoHelp.com Forum
    I've had this program for quite a while even running on Vista but after Microsoft update last night to Service Pack 2 for Vista
    all I get is the splash screen for a few seconds then it goes away and I have nothing?
    Please Help!
  2. Member ChrissyBoy's Avatar
    Perhaps you need to reinstall it?
    I tried to reinstall the registration wizard came up all 3 fields are filled in I click register but now every time I try to start it the registration wizard just keep coming up?
  4. Member ChrissyBoy's Avatar
    I have installed SP2 and registered no problem... So are you running as Admin?
    When I run as admin I immediately get a popup that says svc2dvd 2.5 has stopped working
    OK, I got it! I'm embarrassed to say what I was doing wrong. Rushing through the install I was forgetting to change the path and I suddenly remember the problem with it being installed under Program Files. I changed the path and all works fine ran everything as administrator to be sure.
    Thanks to all that responeded!
  1. [Ask] MPC Stopped Working At every start
    By darkw1zard in forum Software Playing
    Last Post: 24th Mar 2011, 02:41
  2. Avsp won't start
    By vidalien in forum Editing
    Last Post: 14th Mar 2010, 17:04
  3. RipBot won't start up
    By Obamargarine in forum Blu-ray Ripping
    Last Post: 5th Mar 2009, 23:59
  4. PC won't start
    By DuBsTaR in forum Computer
    Last Post: 7th Nov 2008, 23:11
  5. VOB2MPG won't start up
    By lesonja in forum SVCD2DVD & VOB2MPG
    Last Post: 2nd Jan 2008, 12:24
