I am looking to clip plays from video of my son's football games off of different .VOB files and combine them in a highlight video with music as a background while video is playing. I have Cyberlink Power Producer version 3, and it doesn't seem so user friendly and you can't put in music to the video itself, only the menu page. Any suggestions you may have on a good software to import .VOB files, clip parts of them and combine in such a manner for saving as video file and burning to DVD's would be greatly appreciated!!!
I'm not sure about importing VOBs(which are easily converted to mpeg files with other software) but I've been playing with Magix Movie Edit and it's pretty darn easy to use.
The cheaper version is $50.
You can try VOB2MPG and then import the mpg in powerProducer.
Womble MPEG Video Wizard
Answers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video
PowerProducer version 3 works with VOB, though merging clips doesn't seem so user friendly (maybe a more recent version is much better at all that??). What I didn't like most is not being able to attach a song clip to the actual edited video, and that kept me from fooling around to get more familiar with cutting and merging clips. Womble also notes being able to add music to the title/menu page, but says nothing about putting music as the background to the video itself.
Womble is an editor -- a psuedo-NLE of sorts -- you can do whatever you want for replacing audio just fine.
trailers and warnings tool to eliminate and end user friendly
By vanc in forum DVD RippingReplies: 20Last Post: 7th Nov 2010, 11:08 -
User friendly/reliable audio/video synch tool Vista compatible
By wetcamelfood in forum Newbie / General discussionsReplies: 1Last Post: 31st Oct 2009, 18:03 -
video library to xbox360 friendly format
By a7medo778 in forum Video ConversionReplies: 6Last Post: 11th May 2009, 17:55 -
conversion from vhs video to Pioneer 520 DVR to Computer friendly format
By newguy23 in forum Newbie / General discussionsReplies: 4Last Post: 9th May 2008, 02:32 -
Video Converter with best user-friendly GUI
By majax79 in forum Video ConversionReplies: 35Last Post: 13th Sep 2007, 01:33
