VideoHelp.com Forum
    Has anyone used the Emachines EL1300G-01w computer to burn DVD's? I can't find out what brand the burner in it is. I tried to backup a movie and it was breaking up/pixelating. I've not had that problem before with my 7 year old Compaq Presario with a LiteOn burner. I tried burning it in Nero9 at 8X speed, burn at once.
    Anyone else had issues with this burner?
    Thanks in advance.
    Long live the new flesh...
  2. Member Krispy Kritter's Avatar
    My first thought would be a media issue. Either because the firmware is out of date, it doesn't properly support the media being used, or because you are simply using a low grade media.
    Some things to try: 1) a quality media such as Verbatim or Taio Yuden 2) a better burning app - try ImgBurn, it performs better and it's free 3) try a slower burn speed (this can sometimes overcome burner/firmware/media issues.
    As for your burner, try removing the drive and checking the drive label. You could also try a software app such as SIW ( http://www.gtopala.com/ ).
    Google is your Friend
  1. eMachines DV capture possible?
    By GavSalkeld in forum Capturing
    Last Post: 27th Nov 2011, 12:50
  2. second HD on old emachines
    By mac71671 in forum Computer
    Last Post: 18th Sep 2009, 13:51
  3. Can i run a 8400gs on my emachines w3410
    By davidsama in forum Computer
    Last Post: 8th Dec 2008, 22:20
  4. Monitor settings (on Emachines 17" CRT Screen)??
    By willhenderson in forum Computer
    Last Post: 14th Dec 2007, 09:40
  5. IDE DVD Burner VS SATA DVD Burner
    By mn072065 in forum DVD & Blu-ray Writers
    Last Post: 13th Nov 2007, 20:15
