hey guys I have been scratching my head over this, and someone recommended i ask here.
I have windows7 and its awesome.
I am using wmp12, because i like the ability to search video titles fast.
I have alot of codecs installed, and avi files dont play when ffdshow is installed - uninstall it and they play.
I want ffdshow on my computer, so leaving it off isnt an option, especially when wmp12/ffdshow works with the SAME avi file on another computer.
g-spot says the avi files are dx50, so they are xvid i guess.
the files play in km player/vlc etc but i'd like to use wmp if possible.
i have set ffdshows xvid codec to disabled and to xvid and to the ffdshow libavcodec option and still no luck.
can anyone help?
I did some search, but all i got was "wmp doesnt play avi, solution install ffdshow"
for me its the opposite
thanks again
Thread: avi on wmp12
I tried that and i still get errors.
I've disabled pretty much everything in ffdshow trying to rule things out, but it only works when ffdshow is uninstalled
In the early beta versions of W7, the codecs were "locked", meaning that you couldn't, for example get FFDshow to decode XviD instead of the native codecs. Im not sure how it stands now with the latest version.
Any 3rd party codecs are a mess right now on W7, MS basically forces you to use WMF.
You can try clsid's directshow filter changer for w7, it's still beta
http://forum.doom9.org/showthread.php?t=146910
yeah I was sorta hoping it'd work because i have another computer that works with the same win7 build. RC1 (build 7100).Originally Posted by mh2360
Im not convinced windows/wmp is the cause here.
issues to play ac3 audio with WMP12 in windows7 64bit
By deejay.2001 in forum ComputerReplies: 0Last Post: 24th Jul 2011, 19:45 -
Uncompressed AVI plays back in low quality with WMP12 & Pinnacle Studio 14
By textmagic in forum Software PlayingReplies: 2Last Post: 2nd Apr 2010, 04:25 -
No audio .mkv file with WMP12
By poulidis in forum Software PlayingReplies: 4Last Post: 8th Feb 2010, 13:12 -
Dazzle dvc100 w studio 12 does it capture AVI 1 or AVI 2 or DV-AVI
By st711 in forum CapturingReplies: 1Last Post: 10th Dec 2009, 17:30 -
ffmegX v0.09w and converting avi videos into avi.ff.avi videos
By paddymick in forum ffmpegX general discussionReplies: 2Last Post: 2nd Nov 2007, 23:10
