I've had this program for quite some years now and had a problem running it a few days ago. I've tried repairing it with no success. I've also tried uninstalling and reinstalling. Now I'm stuck on the registration part. All the registration info is already in the boxes but when I click register it disappears and I have to go through the process all over again. Can someone please tell me what is going on? What can I do to get it working again? Any help would be greatly appreciated.
Results 1 to 10 of 10
Are you running Vista?
No I'm running WinXP
ok. Please can you drop me an email and we will try it manually?
I'm stuck in this same spot, except I am running vista, I tried the running as admin trick that worked before
but not now.This is after the recent Service Pack 2 update from Microsoft.
If you are running as admin and you still can't get it to work.... drop me an email.
I HAD THE SAME PROBLEM AFTER SP2 UPDATE VISTA 64 BIT TO MAKE IT WORK I DELETED THE SHORT CUT ON THE DESKTOP THEN UNINSTALL THE PRGRAMME MAKE A NEW FOLDER IN C DRIVE C:\SVCD2DVDv2.5 THEN REINSTALL SVCD TO THIS FOLDER ONCE INSTALLED MAKE SURE YOU HAVE NO SVCD SHORTCUT ON THE DESKTOP IF YES REMOVE IT THEN GO TO THE
C:\SVCD2DVDv2.5 INSTALL FOLDER AND MAKE A SHORT CUT TO THE DESK TOP FROM THERE
IT SEEMS LIKE THE SHORTCUT WAS MY PROBLEM TRY DELETING IT AND MAKING A NEW ONE FROM THE INSTALL PROGRAMME BEFORE YOU UNINSTALL THIS SHOULD WORK BUT I HAVENT TRIED IT
Tried what you said and it worked like a charm. Now I'm back up and running. Thanks a lot!
My problem is I already uninstalled it. after re-install all I have is SVC2DVD DEMO, I believe after successful register it creates SVC2DVD.exe, problem being the registration wizard comes up with all my information but it doesn't register?
mkvmerge GUI causes windows explorer to stop working
By codemaster in forum DVD RippingReplies: 6Last Post: 25th Feb 2011, 23:26 -
DVD Shrink and DVD Fab stop working
By Snowdog2112 in forum DVD RippingReplies: 4Last Post: 19th Oct 2010, 09:48 -
WinDV used to work fine ! But not working now
By vatsyk in forum CapturingReplies: 2Last Post: 8th Mar 2010, 05:43 -
Why does doing video editing make other apps stop working?
By brassplyer in forum EditingReplies: 7Last Post: 13th Aug 2009, 10:01 -
DVD drives stop working after burn.
By bob_short in forum DVD & Blu-ray WritersReplies: 14Last Post: 18th Jul 2007, 16:48
