VideoHelp.com Forum
    I tried to create a BD with MultiAVCHD using 3 mkv videos. But the resulted BD (iso created with ImgBurn) shows only black videos.
    Any ideas?
  2. I'm a Poll Super Moderator johns0's Avatar
    The only time i got black screens was authoring mkv that were pal and trying to play on a ntsc sony 350,had to change the fps to 23.976 with tsmuxer and stretch the audio with eac3to to work.
    Ben Johnson-I didnt take any stereos!
    The source is mkv from Blu Ray thus no PAL/NTSC involved (AFAIK).
    I tried to view it with my PC.
  4. I'm a Poll Super Moderator johns0's Avatar
    The mkv has to be either pal or ntsc and depending on your blu-ray player it might not play pal if its ntsc or ntsc if its a pal player,load the mkv in tsmuxer and it will give you the fps.You can play pal and ntsc mkv on a computer with no issue.
    I eventually solved the problem by burning the result to BD.That played fine on BD player and PC as well. I think, something's wrong with imgburn to iso image and/or mounting with Daemontools/MagicISO.
  6. I'm a Poll Super Moderator johns0's Avatar
    Iso probably wasnt udf 2.5 then.
    The only thing in ImgBurn was to change from file to device as destination. Strange, because AFAIK only UDF can store files > 8GB on ISO.
  1. problems with two mkv-movies
    By thenan in forum Media Center PC / MediaCenters
    Last Post: 30th Jan 2012, 17:22
  2. Replies: 4
    Last Post: 8th Oct 2011, 14:49
  3. Replies: 7
    Last Post: 16th Sep 2011, 01:38
  4. MultiAVCHD mkv to 25gb bdr
    By VOYAGER2009 in forum Authoring (Blu-ray)
    Last Post: 25th Apr 2011, 08:37
  5. AVStoDVD or MultiAVCHD? for .mkv 720p on DVD9
    By vandaLo in forum Newbie / General discussions
    Last Post: 30th May 2010, 19:12
