If I rip a DL disk with DVDFab and open the files with DVD Shrink, I get a warning that the layer break may not be in an ideal location. If I proceed with Shrink and burn with ImgBurn, will the resultant DVD be readable? If so, presumably the layer break will be at a bad location - how long does the layer shift take - 1 sec, 3, 5?
I know about PgcEdit and I've used it before but it doesn't want to work with Deadwood Season 1. I'll post details on this later.
Thread: Break on dual layer disk
Are you burning back to DL media ??
If yes, what is the purpose of using dvdshrink ??
Just burn back with Imgburn and set the LB with that.
If you are using dvdshrink to fit it to a dvd single layer, then there is no layer break to worry about.
You're not real clear what your doing here and it does not make much sense
It did not work with/on what ?? A DL dvdr on what ??Originally Posted by audax
I have used PGCedit many times to set layer breaks and it works great, it has actually given me more options for a LB then Imgburn has.
Are you using Verbatim dvd+r DL or some cheap crap ??
Ect. ect. ect. ect.
I could go on with many more reasons but...
Yes, much more specific detail's are needed!!!!!!!!!
Originally a member since 2001, LONG LIVE TARAN's!!!
Dual Layer problem. Layer break issue...
By papegoja in forum DVD RippingReplies: 23Last Post: 9th Jun 2010, 22:52 -
Making a Dual Layer disk with menu
By Regor21 in forum Authoring (DVD)Replies: 7Last Post: 8th Apr 2010, 08:34 -
Sticky upate? When will Dual Layer DVDr disk be available
By JoeBolden in forum FeedbackReplies: 1Last Post: 11th Jun 2008, 03:54 -
Problems with Dual Layer disk burning.
By qaa in forum Newbie / General discussionsReplies: 19Last Post: 21st Apr 2008, 01:47 -
Retail Layer Break and Imgburn Layer Break..the same?
By Moontrash in forum MediaReplies: 2Last Post: 14th Jun 2007, 12:27
Statistics
Newest guides
Latest tool updates
New media comments
