Just installed this application on my Vista machine (newest version). Every time I go to add and avi asset I get a popup that says ffmpeg.exe has stoped working and it wont add the asset.
Any ideas?
Thanks.
Results 1 to 30 of 33
Thread: ffmpeg.exe has stoped working
what are the video and audio details on the avi in question? What does mediainfo give you?
Hi ChrissyBoy
I seem to be getting the same error, I have been using the software all working fine from year dot, it has worked fine on my Windows 7 Beta, but now after installing the Retail Windows 7 I get the ffmpeg.exe has stopped working.
I have tried removing it and re installing it but get same error with any file I try to add
The problem details that are displayed are below
Problem signature:
Problem Event Name: BEX
Application Name: ffmpeg.exe
Application Version: 0.0.0.0
Application Timestamp: 493ceb68
Fault Module Name: ffmpeg.exe
Fault Module Version: 0.0.0.0
Fault Module Timestamp: 493ceb68
Exception Offset: 00448ad0
Exception Code: c0000005
Exception Data: 00000008
OS Version: 6.1.7600.2.0.0.256.1
Locale ID: 2057
Additional Information 1: 0a9e
Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
Additional Information 3: 0a9e
Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
Hope you can help fix this as stuck without it
Is this on adding a file?
Hi yes it is when I add any type of file
Can you give an example file path please?
Hi do you mean the file path of the video file I want to convert
If you do then it would be C:\Users\Admin\Videos\HEROES_2\Heroes.EW03.avi
thanks
Well i have just tried it on my Win 7 RTM and no issues.... So lets try to narrow it down:
Where is SVCD2DVD installed?SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
I have installed it both in the program folder and removed then re installed direct to the C drive but still seem to get the same problem, loads fine just as soon as I try to add a file the ffmpeg error appears.
Some other possibilities, that I thought I'd add:
Do you have a copy of ffmpeg.exe anywhere else in your PATH?
You might post a GSpot screenshot or MediaInfo tree-view information with one of the videos loaded into either utility. Maybe there's something about the videos that ffmpeg simply doesn't like.If cameras add ten pounds, why would people want to eat them?
Hi no ffmpeg anywhere in the path, I have added the gpot view
Whats strange is that it worked fine on windows 7 beta but now after upgrading and to the retail version and re instaling into the same directory it come up with error, I have even tried an old avi file that wrked perfectly while it was in beta
Hi Chris
That's all above my head but I have tried as you said and get the following
not sure if that is what you are looking forC:\BadgerIT\SVCD2DVD is not recognized as an internal or external command, operable program or batch file.
Can you try again.... Make sure both paths are within quotes.
Hi Chris
Sorry for late reply been away, thanks for getting back, I did try again making sure both in quotes but get
The system cannot find path specified
I guess i'm not doing something wrong I have tried placing the avi directly into my C drive but get same as above.
Must admit not the used to using command prompt
Is there anything else I can try, I'm having to use ConvertX2dvd at the moment which is no way near as good as yours so would love to get this fixed.
Thanks again
Can you post the command you are trying please?
i get the same thing when i try to add ANY of my .AVI files that i have i bought this program so i can put them all on DVD and its not working when i try to add the avi file to the asset the ffmpeg.exe error pops up can you please fix this or come up with a solution THANK YOU
Originally Posted by ChrissyBoySVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
so im supposed to put "C:\Program Files (x86)\BadgerIT\ffmpeg.exe" -i "C:\Users\Skeet\Documents\Movies\Stop-Loss" in the command prompt? i put it in exactly like that and it says "C:\Program Files (x86)\BadgerIT\ffmpeg.exe" is not recognized as an internal or external command, operable program or batch file
ok thanks for the descriptiveness ok and i tried it and this is exactly what popped up
Microsoft Windows [Version 6.0.6002]
Copyright (c) 2006 Microsoft Corporation. All rights reserved.
C:\Users\Skeet>"C:\Program Files (x86)\BadgerIT\SVCD2DVD v2.5\ffmpeg.exe" -i "C:
\Users\Skeet\Documents\Movies\Stop-Loss\Stop-Loss.avi" -author john
FFmpeg version UNKNOWN, Copyright (c) 2000-2008 Fabrice Bellard, et al.
configuration: --disable-debug --disable-vhook --enable-avisynth --enable-gpl
--enable-pthreads --enable-libfaad --enable-memalign-hack --enable-swscale --dis
able-devices
libavutil 49.12. 0 / 49.12. 0
libavcodec 52. 6. 0 / 52. 6. 0
libavformat 52.23. 1 / 52.23. 1
libavdevice 52. 1. 0 / 52. 1. 0
libswscale 0. 6. 1 / 0. 6. 1
built on Dec 7 2008 19:00:16, gcc: 4.3.0 20080305 (alpha-testing) mingw-20080
502
and after all that, popped again as usual was the error ffmpeg.exe has stopped working
Can you reinstall the program in a folder other than "Program Files"? See if that helps.
Hi I tried reinstalling it in new folder in C drive other than the program files folder but then got license error due to installing in three machines, so though maybe I needed to update as bought this years ago so before I re purchased it i thought I would try the demo version in a folder other than program files, the demo version worked with no error when trying to add file, so thought great
So I purchased it again and removed the demo, installed the full version in the same folder as I did the demo version, but now get the same error again.
Are you running as Administrator? (Right Click "Run as Administrator" on the exe)
Yes I am running as Administrator and ran as Admin from .exe but still same error
Ok. Can you drop me an email and we will try a few things to get to the bottom of this..... Email will speed things up.
Sorry im a lttle late chrissyboy but i installed it directly to the main drive instead of my programs folder and its still gave me the ffmpeg.exe not working error what else can i do??
Can someone please help me out purchased the program and its still not working please get back back to me as soon as possible
Need mencoder.exe and ffmpeg codecs
By swkenney in forum Newbie / General discussionsReplies: 7Last Post: 6th Dec 2010, 19:41 -
ffmpeg.exe has stopped working error when trying to add asset
By skeet09 in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 27th Oct 2009, 15:15 -
Addresssing Exception in ffmpeg.exe at C0F76
By bitbinder in forum ComputerReplies: 0Last Post: 15th Jul 2009, 16:34 -
Com Surrogate has stoped working
By romanstopme in forum ComputerReplies: 1Last Post: 23rd Feb 2009, 12:16 -
DVD Flick error message "ffmpeg.exe has stopped working"
By stewiegriffin711 in forum Authoring (DVD)Replies: 4Last Post: 17th Aug 2008, 07:20
