VideoHelp.com Forum
Results 1 to 13 of 13
  1. Hi all
    another one project (cross platform with windows) , this one aimed only for ffmpeg
    http://www.64k.it/andres/data/autoff...mpeggui.tar.gz
    you need gtk, xterm and ffmpeg, mplayer for autocrop
    should be quite easy to use, it works on profile, so can be exanded quickly, has a fuctional queue
    it should work, even if is my software
    BHH
    HDConvertToX, AutoMen, AutoMKV Developer
  2. Man of Steel freebird73717's Avatar
    Looks good buzz as always.
    You still using pure basic? I'm considering looking into pure basic myself.
    Donadagohvi (Cherokee for "Until we meet again")
    My Video Tools :: Free Security Software :: Ubuntu Antivirus Rescue CD
  3. yes, purebasic all the way! a very fast languages
    BHH
    P.S. i will send you a pm
  4. update
    added automatic thread support
    some optimizations in source code
    BHH
  5. any feedback ?
    BHH
  6. Get Slack disturbed1's Avatar
    Originally Posted by buzzqw
    any feedback ?
    BHH
    Can't try it out, 32bit only. I checked Pure Basic's site to see if they have a 64bit compiler I could use on your source. PB has a 64bit version in the works.
    The GUI looks nice
    Linux _is_ user-friendly. It is not ignorant-friendly and idiot-friendly.
  7. in my first test i used purebasic on debian 64bit in chroot environment (32bit)... PAIN
    now i am using fedora 32bit..
    anyway.. you can use the application without compiling code ...
    BHH
  8. Get Slack disturbed1's Avatar
    BHH
    The application is compiled for 32bit, so it will not run in a pure 64bit environment.
    file autoffmpeggui
    autoffmpeggui: ELF 32-bit LSB executable, Intel 80386, version 1 (SYSV), dynamically linked (uses shared libs), stripped
    For a 64bit program
    file kino
    kino: ELF 64-bit LSB executable, x86-64, version 1 (SYSV), dynamically linked (uses shared libs), stripped
    If the source code is available, and the compiler supports 64bit, you can compile as a 64bit program. Since PureBasic does not support 64bit binaries, and the source code is 2 Pure Basic files, the application can not be used on a pure 64bit setup, until Pure Basic releases their native 64bit compiler
    ---edit----
    Make that 64bit for Linux, as a Windows 64bit version is currently available.
  9. sorry pal.. but i had run 64bit linux for long time, and 32bit should run without problem
    it's a matter of install 32bit layer (on debian ia32 lib), afaik
    BHH
  10. Get Slack disturbed1's Avatar
    BHH
  11. ok ok.. don't flame!
    i know that SubGenius are zealot... but please.. some lib don't grip your system...
    it isn't windows...
    BHH
  12. Get Slack disturbed1's Avatar
    it isn't windows...
    BHH
    Not a flame, just requoted to make sure you saw what I wrote
    I could install a 32bit compatibility layer, but honestly, I find it non essential. Plus there are only a handful of applications that are not 64bit. Wine and everything Google (Picasa, Earth, Chromium). Though 64bit wine is in the works.
    I'm waiting on PB's 64bit Linux release. After looking at your source code with PB in KVM, it's actually straight forward, and quite intuitive. So much easier than qt-creator
  13. update gui, same link
    some bug fixing
    little restilyng to gui
    BHH
  1. Full FFMpeg/Mencoder gui?
    By TSJNachos in forum Video Conversion
    Last Post: 16th Jun 2011, 02:24
  2. AutoFF a new gui for FFmpeg (v. 0.99.8)
    By buzzqw in forum Linux
    Last Post: 16th Aug 2010, 09:49
  3. Best GUI for ffmpeg encoding
    By usta in forum Video Conversion
    Last Post: 7th Sep 2009, 13:59
  4. Recommend a GUI for FFmpeg
    By David_UK in forum Video Conversion
    Last Post: 2nd Feb 2009, 07:35
  5. My new FFmpeg GUI - Kiss DTV 2 DVD
    By slmnow in forum DVB / HDTV
    Last Post: 21st Nov 2007, 10:46
