VideoHelp.com Forum
Results 1 to 9 of 9
    Hi
    Im basicly looking for a piece of software for use in a live show that would be able to mainly support 2 camera inputs and also play a video. It would need to be able to simply fade between these different sources and output to a projector. I did come accros a piece of software called "Whizzualizer" and this did everything i wanted except there was no audio when playing the video.
    Any help or advice on this would be greatly appreciated,
    Jack
    I think you misunderstood me, the cameras are live imputs, this is for a live show
  3. Member maldb's Avatar
    Don't know about software. - you might have to go the hardware route. I have a Panasonic WJ-AVE5 A/V mixer and it's great. I purchased it new back in the day for over $1000(!) - you can get them on eBay for less than $200. It has 2 A/V inputs: composite and S-video and multiple outputs and an array of special effects that would be cool for a live show. Good luck.
    Low-cost hardware solution: one of the Edirol video mixers. Model selection depends on source type (analog or digital; SD and/or HD).
    http://www.edirol.com/index.php?opti...=84&Itemid=421
  5. Member maldb's Avatar
    I don't know about low-cost - they start at around $1100 (V-4) and go up to around $10K. The V-4 is a nice little unit - Standard Definition only - 2 S-video inputs or 4 composite inputs.
    Here's a comparison chart: http://www.edirol.com/index.php/en/p...mparison-chart
  6. Member olyteddy's Avatar
    I don't recall where but I remember reading about software that could blend two DV sources on the fly.
  7. Mod Neophyte Super Moderator redwudz's Avatar
    Maybe the one from JohnnyMalaria: http://forum.videohelp.com/topic356055.html But I believe that's just for DV sources. If so, the used video mixer suggestions would be one way to go for a economy setup.
  8. The Old One SatStorm's Avatar
    Just for the info: one camera and one videosource, can be done with virtualdj.
    La Linea by Osvaldo Cavandoli
  1. Replies: 20
    Last Post: 17th Mar 2012, 11:04
  2. Replies: 0
    Last Post: 24th Aug 2011, 02:00
  3. Live HD video mixing - which software/Hardware ?
    By Edwoo11 in forum Software Playing
    Last Post: 13th Apr 2011, 15:10
  4. Replies: 1
    Last Post: 27th Jan 2011, 23:18
  5. Eyecopia Security Video Software not finding Internet Connection
    By PeterD in forum Newbie / General discussions
    Last Post: 2nd Dec 2009, 17:53
