VideoHelp.com Forum
    Hey,
    During the last couple of days I've been searching in all kinds of forums for a good guide to convert Blu-Ray to PS3 compatible mp4 files. And I did find some good guides. Thus I cut out a 5 minutes clip from a Blu-Ray and encoded it with MeGui and various profiles like, DXVA-HD-Fast, DXVA-HD-HQ, and the PS3-Xbox360 profiles. The video had two audio streams in AAC 5.1 and a resolution of 1080x816 and everything played fine on the PS3.
    However, when I encoded the entire movie with the same profiles I cannot play it on the PS3. I get an error message (80028801). How is this possible? I tried streaming it with TwonkyMedia and I compied it to the console, but nothing works. I still get the same error message. Could you please help me figuring out why it won't play?
    Here are the video specs:
    Format : MPEG-4
    Format profile : Base Media
    Codec ID : isom
    File size : 6,33 GiB
    Duration : 1h 43min
    Overall bit rate : 8 723 Kbps
    Video
    Format : AVC
    Format profile : High@L4.1
    Format settings, CABAC : Ja
    Format settings, ReFrames : 2 frames
    Codec ID : avc1
    Duration : 1h 43min
    Bit rate mode : variabel
    Bit rate : 7 976 Kbps
    Maximum bit rate : 16,8 Mbps
    Width : 1 920 Pixel
    Height : 816 Pixel
    Display aspect ratio : 2.35
    Frame rate mode : konstant
    Frame rate : 24,000 FPS
    Resolution : 24 bits
    Colorimetry : 4:2:0
    Scan type : progressiv
    Bits/(Pixel*Frame) : 0.212
    Stream size : 5,79 GiB (91%)
    Writing library : x264 core 67 r1169M ab85c9b
    Encoding settings : cabac=1 / ref=1 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=5 / psy_rd=0.0:0.0 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0 / threads=6 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40 / rc=2pass / bitrate=7976 / ratetol=1.0 / qcomp=0.50 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=24000 / vbv_bufsize=24000 / ip_ratio=1.10 / pb_ratio=1.10 / aq=1:1.00
    Audio #1
    Format : AAC
    Format version : Version 4
    Format profile : LC
    Format settings, SBR : Nein
    Codec ID : 40
    Duration : 1h 43min
    Bit rate : 372 Kbps
    Maximum bit rate : 494 Kbps
    Channel(s) : 6 Kanäle
    Channel positions : Front: L C R, Rear: L R, LFE
    Sampling rate : 48,0 KHz
    Resolution : 16 bits
    Stream size : 276 MiB (4%)
    Audio #2
    Format : AAC
    Format profile : LC
    Codec ID : 40
    Duration : 1h 43min
    Bit rate : 372 Kbps
    Maximum bit rate : 495 Kbps
    I would try stream using ps3 media server and see if it works any better...to rule out the streaming application.
    Streaming with PS3 Media Server works, but I can only play the videos when the server re-encodes them. However, the original file won't play. How can that be, using a PS3 profile in MeGui?
  4. I think the thread is dead. But anyway I think mp4 can transport only 1 audio stream. Try m2ts with ac3 audio.
  1. Can i burn avi/mp4/mkv etc to blu ray media and play it in a blu ray player
    By brad350 in forum Newbie / General discussions
    Last Post: 21st Apr 2012, 04:15
  2. Copyed Blu ray won't play in blu ray player
    By gweedow in forum Video Conversion
    Last Post: 13th Jan 2011, 14:58
  3. Blu-ray backup won't play in PS3
    By DGenerateKane in forum Blu-ray Ripping
    Last Post: 27th May 2010, 00:57
  4. 1080p Mkv To DVD-DL 8.5 Gig To Play On PS3 and Blu Ray
    By Chevy434 in forum Authoring (Blu-ray)
    Last Post: 20th May 2010, 04:04
  5. mkv, x264, and h.264 to blu-ray to play on PS3
    By cyberpimp16 in forum Authoring (Blu-ray)
    Last Post: 14th May 2009, 14:58
