VideoHelp.com Forum
    I copied m2ts files straight to a DVD-9 disc and it works fine. But when I created an AVCHD folder on a DVD-9 disc using AVCHD, it showed me error 80029946 - This video cannot be played. A search reveals that the error means the following:
    "Attempting to play burnt Dual layer NTSC disc on a Pal ps3."
    But I have an NTSC PS3. And like I said before the m2ts files play fine as data files on the DVD-9 disc.
    Using AVCHD? Do you mean multiAVCHD?
    Sorry, ... yes I used the MultiAVCHD software to create the AVCHD folders and menu content. I copied the two folders that in the AVCHD directory created by MultAVCHD and burned the DVD-9 disc using ImgBurn. No ... the AVCHD directory was not copied on the disc, only the two subdirs were burned on to disc.
    So when I enter the into my PS3, the menu appear, but when I select play, that is when the error message appears.
  1. software to batch convert m2ts format avchd to mts avchd?
    By masterpug in forum Video Conversion
    Last Post: 14th Aug 2010, 01:06
  2. how to make BD Video disc using m2ts files
    By vikas.babu in forum Authoring (Blu-ray)
    Last Post: 20th May 2010, 01:49
  3. Replies: 7
    Last Post: 27th Feb 2010, 21:54
  4. WinDVD 9 Plus BlueRay will not play m2ts AVCHD files
    By deejay.2001 in forum Software Playing
    Last Post: 14th Jul 2008, 08:33
  5. Working with m2ts files backed up from Blu-Ray disc
    By Lovepeaceguru in forum DVD Ripping
    Last Post: 15th Dec 2007, 06:55
