Results 1 to 12 of 12
    Hi
    I have now a basic but nice scriptcode in batch that I can easy create AVI for the program I recording on TV.
    The problem is this
    I have some MPEG file that I like to convert, and I use Mencoder (Love that program).
    That I do is open my Batch file and add line to each MPEG file, I have to look if that is in 4:3 or 16:9 the source.
    Then I have to open a biterate Calculator to have have a good size of my movie (I have a little rule that biterate have to be over 1000 for a movie)
    After that I start the batch file and it start to create the AVI file
    Now I was thinking maybe create a file (Batch or VBscript) that can read the MPEG size and length, So I just have to add the MPEG file in a folder and then run the script.
    But can VBscript/Batch read MPEG file??
    You can't read MPEG files directly in VBScript, but you can use an ActiveX build of MediaInfo in VBScript . See http://mediainfo.sourceforge.net/en/.../SDK/ReadFirst for more details (there are VBScript examples included in the download).
    I dont find any information. I dont like to program a VB program or C, just clean VBscript.
    Do you know where I can read about how I can make a VBscript to read MPEG file?
  4. Member ChrissyBoy's Avatar
    ohh ok thanks
    lolz
    Hmm did find alot of other exampel but not any VB Script?
    Hmm... I suspect that you have downloaded the wrong version, as I can clearly see the VBScript example.
    1. Go to the download page and select the Windows version.
    2. Then download the DLL version (32 bit or 64 bit, which every one you require).
    3. Install\extract the exe\7z
    4. Then navigate to the "Developers\Contrib\ActiveX\Example" directory
    Sorry guys but I am useing Windows 7 and I don't find this directory you are referring to. There is no Developers folder in the root, in Program Files, in Program Files\MediaInfo, in Program Files\MediaInfo.dll\ or in the Windows directory. I have done a search for Contrib as well but nothing.
    Sorry for being a pain but could someone post the VBScript samples?
    I have searched the net but nothing so far.
    No, I think you've downloaded the wrong file. Go to the Windows download page and download the DLL version of MediaInfo (download the 32-bit version if you want the VBScript examples as it is currently omitted from the 64-bit version). I suggest downloading the zip version (without installer) so that you can find the files much easier.
    Regards,
    Thanks very much, can't believe it was that simple. Now I am having a different problem, can't register the dll file. Get the error: The module ... was loaded but the entry point DllRegisterServer was not found.
    Any ideas.
    Any ideas.
    Which DLL are you trying to register (there's more than one)?
    Navigate to the ..\Contrib\ActiveX\Release directory, and you should find the correct DLL, along with useful install\uninstall batch scripts.
    Regards
  1. VBScript to read XML. Assistance Needed
    By NYPlayer in forum Programming
    Last Post: 4th Oct 2009, 16:11
  2. Replies: 0
    Last Post: 17th Sep 2006, 13:55
  3. Create a batch file to demux all these mpeg-2s at once
    By Garibaldi in forum Newbie / General discussions
    Last Post: 13th Dec 2005, 00:12
  4. Tmpgenc plus can't read mpeg-2 file
    By magwell in forum Video Conversion
    Last Post: 9th Mar 2003, 22:43
  5. after using Tmpgnec-what should the file read-mpeg-vcd
    By slowpok in forum Newbie / General discussions
    Last Post: 5th Mar 2003, 08:04
About   Advertise   Forum   RSS Feeds   Statistics   Tools
