VideoHelp.com Forum
    I searched this topic but I have not found a clear cut answer. If I copy multiple m2ts files to a DVD or DVD-DL will the PS3 see all the files and play them? When you insert a DVD, the PS3 will tell you that it has found and AVCHD disc and then you just select play to play the disc. So if I have multiple m2ts files ... what will happen?
    Will it just recognize the first file and ignore the rest or do I have to place the files in a specific AVCHD folder?
    If you burn the mt2s files as data then you will seem them listed and you can choose which file you would like to play from the PS3 menu.
    If you want to create a true AVCHD disc then you need to author it in a manner not dissimilar to DVD authoring. Try looking at Multi-AVCHD as an option. It will let you author multiple files and creates a menu for you as well.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
    Guns1inger,
    Exactly the answer I was looking for. I read about Multavchd but was not sure about how the PS3 handled multiple m2ts files on a DVD without any directory structure.
    Thank you very much,
  1. Blu ray for ps3 with m2ts files
    By ssangwan in forum Authoring (Blu-ray)
    Last Post: 29th Feb 2012, 23:46
  2. Merging/Converting Multiple M2TS files to MKV With Multiple Audio Tracks
    By Nicholas S. Folsom in forum Video Conversion
    Last Post: 13th May 2011, 18:34
  3. Help with multiple .m2ts files to one .m2ts
    By neworldman in forum Blu-ray Ripping
    Last Post: 17th Mar 2010, 19:39
  4. advice for editing m2ts files from ps3
    By acnescar in forum Newbie / General discussions
    Last Post: 10th Jan 2009, 17:54
  5. i need to split m2ts files for PS3
    By domerdel in forum Editing
    Last Post: 11th Nov 2007, 01:36
