VideoHelp.com Forum
  1. Member fritzi93's Avatar
    Originally Posted by OMGretards
    Whenever i turn it on it turns back off within 5 min! What do i do?
    You have to do better than that, it's not enough information.
    By "it" I presume you mean the computer? That symptom, by itself, would suggest overheating. Have you ruled that out? And what makes you think the problem is a virus?
    How is this germane to the capturing forum?
    Pull! Bang! Darn!
    How do you know it's a virus?
    What anti-virus sw are you running?
    Did you get an alert?
    Could be that your system is over heating
    Oh by the way your in the wrong forum.
    Jump into safe mode ... if it stays powered up then grab malwarebytes, install, update, let it rip ... at end, show results, and click remove objects found, reboot back into safe mode.
    If not able to stay powered up in safe mode then
    a: Remove all non-essential connected peripherals... and if kids around, check they haven't jammed a coin into usb slots ... it happens around here, lolll
    b: Remove any non-essential addon internal cards (if onboard video available and your using addon gpu, remove and go back to onboard for tests)
    c: Clear "dust bunnies" from fans gently (system power off and power removed first).
    d: Pull all data cables and reinsert them ... they can come loose or not be fitted properly.
    Try in safe mode now
    e: If no go, quickly when in safe mode uninstall any ms update applied around time of system fault developing ... yes, ms has once again started delivering some buggy updates of late... reboot back into safe mode.
    Still ?
    f: Boot the thing with a bootable linux distro ... any will do as test we want to see if it can stay up and running which might point to a major issue with the windows os.
    Still no go, time for final plug
    g: Try another psu ... the current one may have issue's
    h: Replace heatsink compound ... replace with artic silver 5 paste ... just follow the instructions it comes with.
    If after all this, scrap the os and reload from new... failing this would lead to motherboard at fault
    I'm fairly sure this guy is a spammer. All his other posts have been generic and not particularly appropriate, typical of forum and blog spam: http://forum.videohelp.com/search.ph...hor=OMGretards
  5. Mod Neophyte Super Moderator redwudz's Avatar
    OMGretards was banned for spamming.
  6. Member Noahtuck's Avatar
    Well, his name was OMGretards
    Originally a member since 2001, LONG LIVE TARAN's!!!
  1. My Windows 7 i5 Computer...Virus?
    By Tom Saurus in forum Computer
    Last Post: 26th Dec 2011, 16:46
  2. Possible Computer Virus-Trojan Issue
    By Frank-0-Video in forum Computer
    Last Post: 11th Apr 2011, 20:57
  3. computer virus turns 40
    By deadrats in forum Computer
    Last Post: 21st Mar 2011, 09:37
  4. Replies: 24
    Last Post: 27th Apr 2010, 10:58
  5. Have a Virus? Buy a New Computer!
    By 3Simon7 in forum Computer
    Last Post: 28th Oct 2009, 04:50
