VideoHelp.com Forum
    I'm converting an mkv file with h264 video and aac audio to a xvid .mp4 file to play back on my media drive, but i've run into a problem with mp4box.
    My Steps are as follows.
    1. Demux MKV using mkvextract
    2. Convert Audio AAC-WAV-MP3 Using FAAD & Lame
    3. Convert Video to Raw XVId Stream using ffmpeg/mencode
    4. Mux the Raw xvid video stram and mp3 audio to an mp4 container using MP4Box
    the problem I'm encountering is that mp4box just keeps building the temp iso file until the file size reaches the max file size for the os, for example my video file and audio file combined are 4.5gb, mp4box keeps building the mp4 file until it reaches more than 16gb.
    If I specify a length for the import using the %n flag in the input file name mp4box works but this causes the audio to drop out after the first few seconds.
    Tried latest mp4box 0.4.6 beta/dev also?
    And you could also try mux using ffmpeg(ffmpeg -i videofile -i audiofile -vcodec copy -acodec copy new.mp4) or mp4muxer.
    I've tried a few different builds of mp4box, but not the beta yet, I'll try that.
    ffmpeg seems a little buggy when muxing to mp4 especially when there are b-frames in the video stream, but I can get past that by specifying 0 bframes when transcoding to xvid.
    I'll try mp4creator / mp4muxer
    Just a quick update, ffmpeg seems to work fine, I still need to test the mp4 file on my ,media player but it works fine in vlc.
    The beta of mp4box still continues to build a huge file regardless of the size of the input.
    mp4muxer does not seem to support mp3 sound properly and creates a non standard mp4 file that even vlc does not open.
    seems Im stuck using ffmpeg for muxing, which means I can not include chapters etc....
    Just an update to this, It seems to be a bug in mp4box when trying to mux raw xvid streams, when I use mpeg4 as the raw stream it works perfectly.
  1. 24 FPS in mp4box?
    By Prodige440 in forum Video Conversion
    Last Post: 7th May 2011, 10:51
  2. MP4box question...
    By userpc in forum Editing
    Last Post: 6th Oct 2010, 08:13
  3. concatenation problem with MP4Box
    By kaymyst in forum Video Conversion
    Last Post: 15th Dec 2008, 06:28
  4. MP4Box-help
    By FallenAngelII in forum Video Conversion
    Last Post: 4th Dec 2008, 22:01
  5. mp4box crash
    By ckamc in forum Video Conversion
    Last Post: 8th Feb 2008, 06:49
