    Does anyone know if I can obtain 1920x1080 Windows resolution from PC-to-HDTV without HDMI cable?
    I currently have VGA/PC cable to HDTV and cannot exceed 1360x768 Windows resolution so I cannot see full HD when playing 1920x1080p movies from my PC.
    I have tried DVI-HDMI cable but it introduces a lot of grain and weird lines in movies.
    What can I do?
    Thanks.
    If your graphics card can (with the latest drivers) output a 1920 X 1080, and if your HDTV can accept 1920 X 1080 through the VGA cable, then yes.
    However I suspect that your TV cannot accept 1920 X 1080 if it is currently only connecting at 1360 X 768. You will have to consult your TV manual to confirm what it can do over VGA.
    As DVI/HDMI is a digital signal you should not be getting distortions unless the cables are substandard.
    Read my blog here.
    Thanks. After reading your post I consulted the TV's manual and it seems my TV does not accept resolutions over 1360x768 via VGA/PC input.
    The manual said only HDMI can accept 1920x1080 on my TV. Bah!
    I just don't know why connecting with HDMI introduces a lot of grain and horizontal fine lines in movies.
    I will try buying a different DVI-HDMI cable.
    Thanks again.
    leopardx,
    What is the make/model of your HDTV? I'm guessing its native resolution is 768p. Check the manual to verify. If it is a 720/768p then even if the HDMI port allows for 1080, its downscaling the video to 720p (then again up to 768 if needed).
    Have a good one,
    neomaine
    NEW! VideoHelp.com F@H team 166011!
    http://fah-web.stanford.edu/cgi-bin/...teamnum=166011
    Folding@Home FAQ and download: http://folding.stanford.edu/
