  1. Just finished building my "ideal" machine, and in addition to the i7, 12 Gigs of RAM, 2 Radeon HD 4870 cards with CrossfireX, and two HDs (one 80 GB for OS, one 1TB for data) I added an LG Blu-Ray Drive and an Asus VW 246H monitor.
    When I run the Cyberlink advisor software that came with the LG drive, it claims I won't be able to playback a Blu-Ray disc because I don't have an HDCP monitor. So I haven't gone out and bought anything yet because I'm worried it's correct. Is this a false negative? Is there an easy/cheap fix? Or am I SOL?
    Thanks in advance,
    Ewan
    How is it connected? HDMI ? everything has to be HDCP compliant in the chain of connections
  3. Yes, it's connected via HDMI although it also has a DVI port, though I understood that wasn't as "desirable", and it has a VGA port too.
    Well, if you're running XP, then its 8.5gb wasted RAM. If its Vista, probably only 8gb wasted.... Really why so much RAM? And comparatively, so little drive space? What could you be doing that would be so RAM intensive that you wouldn't need a second hard drive to segregate the read/write? And, 2x 4870s? Must be looking for some heavy FPS in some newer games... If it was for HTPC, way way overkill.... anyway, your dollars...
    For the monitor with lack of HDCP, purchase AnyDVD HD. Not sure what the current price is, and I haven't used it for this purpose, but it should disable the checking of HDCP when playing BR discs on your PC.
    Have a good one,
    neomaine
    NEW! VideoHelp.com F@H team 166011!
    http://fah-web.stanford.edu/cgi-bin/...teamnum=166011
    Folding@Home FAQ and download: http://folding.stanford.edu/
  5. Originally Posted by neomaine
    Running Vista Ultimate 64 which uses 12 gigs just fine. The 12 gigs is because the i7 uses DDR3 rather than DDR2, so you like to have the same amount of RAM for each channel.
    To clarify, I have an 80 Gig HD AND a 1 TB HD. Idea is that your cache is on the smaller drive (which since it's smaller the heads can get where they are going faster), and then the data and work are done on the big HD. I also have an external 1 TB HD and two 1TB NAS devices - but wasn't including them since they aren't part of the system.
    Actually I do game programming (more at my site - EGAWorks), and most of the newer 3D packages support the multi-core, and you want the fast video so you can do your preview renders quickly. The HTPC is just a nice side feature.
    Will give it a look see. Thanks!
    Wow, someone who actually can use the hardware they've setup. Sorry, that's rare around here...
    Have a good one,
    neomaine
    I was about to purchase an ASUS VW246H until I saw this. According to the ASUS site this monitor has HDCP support. Does it not? Can anyone recommend a similarly priced 24 inch monitor with HDCP support?
  1. Are there any 100% working methods for Blu-ray TO Blu-ray ?
    By Tyrexionibus in forum Blu-ray Ripping
    Last Post: 19th Oct 2009, 09:55
  2. Replies: 4
    Last Post: 16th Jan 2009, 09:07
  3. Replies: 5
    Last Post: 5th May 2008, 17:05
  4. My Sony Blu-ray player BDP-S1 does not recognize my Blu-ray Disc
    By showgirl in forum Newbie / General discussions
    Last Post: 2nd Oct 2007, 13:48
  5. First Blu-ray disc drive won’t play Blu-ray movies
    By akrako1 in forum Latest Video News
    Last Post: 14th Aug 2006, 00:30
About   Advertise   Forum   RSS Feeds   Statistics   Tools
