VideoHelp.com Forum
Results 1 to 10 of 10
    I'm stuggling with joining m2ts files (using tsMuxer version 1.10.6).
    I got already two BD discs which have the same problem
    - Steven Spielbergs' Close Encounters of the 3rd Kind
    - Hancock
    Both of them have split the main movie into several .M2TS files. When I join them using tsMuxer into one single .M2TS file, then this file gets stuck after reaching the "joining-moment" (but each single element is played without any problem)
    additional information: Video - h264, Audio - DD-TrueHD (with AC3 core)
    I face the same problem when joining M2TS files from my Canon AVCHD camcorder HF11 !!!
    When I join files which are created directly by this camcorder, they again get stuck after playing the "joining-moment"
    additional information: Video - h264 (24Mbps), Audio - DD - 2 channels
    I'm always using for playing the Popcornhour 110 - Network Media Tank (HW decoded media player, see www.popcornhour.com) which works great with all other single-M2TS rips from BD discs (encoded in h264, VC1 or MPEG2) and regular DVD VOB files as well.
    Do you have similar experience? Do you know how to resolve it? How to join .m2ts files together correctly?
    Are you using BD Info to load the correct mpls file into TsMuxer on these "seamless branching disk" titles?
    If not, this what you need to do
    ocgw
    peace
    Athlon II Propus 630 @ 3.62Ghz / 8GB DDR2 1066 5-7-7-20 / 8x BD-RW / 19TB Storage
    http://forum.videohelp.com/topic368691.html
    Yes, full BD disk is copied to HD, and then proper MPLS file identified to load the right sequence of .m2ts files, then irrelevant audio and subtitle streams excluded, and finally processed using tsMuxer. I tested several combinations (i.e. exclude only some audio elementary stremas, none of them, etc.) but result is the same - always stucking during playback once the "join-point" is reached. Typically only on those multi .m2ts discs. If there is only one big file (which is in most cases - fortunately ), then processing and exclusion of unwanted audio stream works fine.
    I'm quite unhappy since it happens also in case of my own video from AVCHD camcorder.
    You got the latest firmware, drivers and software for popcorn hour?
    ocgw
    peace
    Yes, I did. Popcornhour firmware from 1 June 2009 - still no change. I suspect that tsMuxer doesn't join files correctly, meaning that timemarks in the stream are not updated 100% correctly or multiplexing of elementary streams has some gaps. Software-based players in MS Windows are probably able to handle this gap but Popcornhour not. (Please note that Popcornhour plays original single-file-m2ts movies without any problem - even long 2.5 hours movies
    That's why I'm asking if somebody has similar experience and knows how to overcome/fix it it.
    You could try Clown BD, it demuxs w/ eac3to, and remuxes w/ TsMuxer
    http://forum.slysoft.com/showthread.php?t=25818
    ocgw
    peace
    Looks very promising! I tested it with AVCHD files (joining .m2ts) and it worked .
    I demuxed AVCHD files from Canon camcorder using
    eac3to -demux 00001.m2ts+00002.m2ts+00003.m2ts+...
    which also joined those files (this is important for me) and created elementary video and audio stream/files.
    Then I merged those elementary streams using tsMuxerGUI.
    Resulting .m2ts file payed smoothly and correctly on my Popcornhour !
    It looks to me that tsMuxer (1.10.6 and older) has some bug while demuxing transport stream (.ts and .m2ts) - maybe dropping few filler-packets or whatever. It may happen during demuxing both internally (while joining) and externally with demux command.
    I will provide a conclusion once I will test in also with those problematic BD discs: "Close Encounters of the 3rd Kind" and "Hancock", probably after Sunday
    Good to hear it seems to be working out for you
    ocgw
    peace
    So, after watching the joined .m2ts file of BD "Close Encounters of the 3rd Kind" I can confirm the successful .m2ts joining process :
    I used command
    eac3to -demux 00055.mpls
    which joined all partial .m2ts files as described in BD playlist 00055.mpls and created all elementary video and audio stream/files.
    Then I merged those elementary streams using tsMuxerGUI (including Dolby TrueHD and DTS-HD MA sound!).
    Resulting single .m2ts file payed smoothly and correctly on my Popcornhour !
    ocgw - thanks a lot for good hint and advice.
    I used command
    no problemo
    ocgw
    peace
  1. Replies: 2
    Last Post: 20th Mar 2012, 04:47
  2. I can not add .m2ts files into TSMuxer
    By yaoyao0204 in forum Blu-ray Ripping
    Last Post: 25th Nov 2011, 20:00
  3. Replies: 6
    Last Post: 28th Aug 2011, 17:44
  4. Joining m2ts files
    By theendisnye in forum Authoring (Blu-ray)
    Last Post: 21st May 2011, 11:51
  5. Audio drifting when merging Sony .m2ts files in tsMuxeR
    By jaholmes in forum Authoring (Blu-ray)
    Last Post: 28th Sep 2009, 12:02
