Hey again guys,
Just something i've noticed, is Media Player Classic only able to use one CPU core? I found out as i was playing a rather large .mts file and it seemed to be chopping a bit so i looked at what was being used to see if i could figure out the issue and speed it up. I noticed the vast difference in CPU usage (Attached Image if it works!)
It's probably just my ignorance again, but are are all the easy simple players (MPC, VLC etc) single core only? Does this cause playback issues for many others often?
I'm on an older machine at the moment so my Spec is not listed as is in my profile which would be why i'm discovering it now.
Problem playing wmv files in Windows Media Player and Media Player Classic.
By rayden54 in forum Software PlayingReplies: 4Last Post: 1st Aug 2008, 23:49 -
AMD 4200+ Single Core to Dual-Core Upgrade Issue...
By Bodyslide in forum ComputerReplies: 7Last Post: 30th Nov 2007, 16:45 -
Windows Media Player OR Media Player Classic REMOTES?
By Xenogear900 in forum ComputerReplies: 2Last Post: 7th Dec 2006, 17:04 -
Dual Core Computer or Single Core with a higher clock speed?
By starwarrior29 in forum ComputerReplies: 3Last Post: 21st Apr 2006, 02:36 -
Is a dual core or single core better for capturing?
By Rudyard in forum CapturingReplies: 30Last Post: 14th Feb 2006, 00:24
Statistics
Newest guides
Latest tool updates
New media comments
