every time I click a video file to play, only Windowmedia or Nero are shown as opiton. If I want to play VLC, I have to start it first and then open file to choose the video file. Never have this problem with XP. Can s.o. know how to resolve this problem? Thank you.
Results 1 to 14 of 14
I'd like to help but this is a Mac. Be back later.
http://www.kiva.org/about
OK, on Vista Ultimate.
"Right click"... "Open with" ... then "Choose default program"
VLC should be one of the choices if installed.
If you want VLC to be the default, check the box.Recommends: Kiva.org - Loans that change lives.
I already tried, VLC is not on the list.
You have to manually search for vlc to have it on the list by using the browse button when you open with...
Ben Johnson-I didnt take any stereos!
I already tried all, still can't geit it. the VLC does work on my Vista ultimate but it just can't be the default player. even when I maually put it on the list of sofware, it still can't get on the list. don't know why.
You need to go into the default programs in the control panel and make VLC the default player for whatever file extension you are trying to play.
Believing yourself to be secure only takes one cracker to dispel your belief.
Are you an administrator on your PC ?
this is know bug in windows.
i do not know why it ocurrs and how to solve it.
i have the same on one of my machines. i just cant get Splash on the list for "open with". i choose splash.exe and it doesnt appear on the list. this is weird.
i read somewhere that editing registry may help. but doesnt work for me :/
I've had no problem with my Vista Ultimate or the Vista Premium.
When you install VLC, it asks if you want to 'associate' files with it. Click that box and VLC will show up in your context menus as a choice. It works fine with Vista Ultimate on two installations I have. Just un-install and re-install and choose that option and it should work. I would also select not to use the existing settings, just redo your preferences after installing.
Install VLC? I download a zip file, then unzip it, and it works but it is not working as a default player.
I got in the official site and downloaded again. I chose the first link with 15.9mb and had no problem.
If I chose the third link with 26mb, it did not work with my vista ultimate.
can't explain why, but the problem is solved.
virtualdubmod and vista ultimate
By volam1 in forum Video ConversionReplies: 1Last Post: 25th Sep 2009, 11:09 -
Using DVD43 with Vista Ultimate 64?
By tigertribe in forum Newbie / General discussionsReplies: 4Last Post: 5th Jun 2008, 15:09 -
How to install Vista Ultimate 64 with raid5
By mysts in forum ComputerReplies: 3Last Post: 4th Aug 2007, 21:49 -
Boot Vista Ultimate USB/CD
By mol3000 in forum ComputerReplies: 0Last Post: 17th Feb 2007, 01:35 -
svcd2dvd and vista ultimate
By bighun in forum SVCD2DVD & VOB2MPGReplies: 16Last Post: 30th Dec 2006, 18:11
