Can someone help please? In the past, I have recorded DVD data discs with avi files on them & they play back fine on my 2 DVD players.
Now I am burning 720p HI-DEF DATA D/L discs and they play fine on my PC...but of course not on my current DVD players. Will they play on any BluRay player.....not sure what to look for or buy. I hope someone can help. Many thanks. artmcclin
Results 1 to 9 of 9
Thread: HI-DEF 720p DATA DISCS
Western Digital TV HD Media Player, aka WD TV.
Popcorn Hour.
If you use avchd it should play on most bluray players including the ps3.
But as jagabo mentioned a media player that connects to a harddrive might be a more attractive option to you. No discs needed. Just transfer the compatible file and your all set to go.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
There's also mod firmware for the WDTV that supports external USB DVD drives (not for movie DVD, just for UDF/ISO data).
It is unlikely artmcclin is downloading AVCHD files.
http://www.kiva.org/about
I don't suppose you'd care to post a link to that, would you? Because I saw you talk about this in another thread today too. I spent a little time going through the time consuming AVS Forums and all they are talking about recently is the wireless mod firmware.Originally Posted by jagabo
Here, I think: http://b-rad.cc/wdtv-firmware-dvd-enabled (I don't have a WD TV, just going by what I've read).Originally Posted by jman98
Thanks, jagabo! I definitely did not find that one with my previous searching.
Creating High Def (AVCHD) Discs on a Mac?
By ehmjay in forum MacReplies: 0Last Post: 15th Nov 2009, 00:11 -
Which specifications should I be looking for to play my data discs?
By K_Kat in forum DVD & Blu-ray PlayersReplies: 12Last Post: 5th Jun 2009, 11:53 -
Will 720P and 1080P dvdr discs play on a Non Blu Ray DVD Player?
By donfm in forum Newbie / General discussionsReplies: 21Last Post: 31st Mar 2008, 15:45 -
dvd data discs
By skudra in forum Authoring (DVD)Replies: 0Last Post: 23rd Aug 2004, 17:39 -
Pioneer 106D burning data discs
By baps in forum DVD & Blu-ray WritersReplies: 13Last Post: 5th Feb 2004, 00:06
