    looking for help on buying a player that when you put in pause it does not switch off after
    a limited amount of time
  2. VH Wanderer Ai Haibara's Avatar
    Why do you need a unit that won't turn off/release pause after a short period of time? That's normally a bad idea - most units don't let you leave them in pause for a long time because it can cause damage to the unit.
    Why not hit Stop instead, and just hit Play again when you're ready to resume? That's less likely to cause problems. You may need to disable your player's automatic-power-off features, if possible, though.
    its for use in presentaion which will also have a video camera running and
    a powerpoint presentaion running and dvd
  4. Member Dv8ted2's Avatar
    Just turn the player on when needed. There is no sense on wearing out the player.
    Believing yourself to be secure only takes one cracker to dispel your belief.
  5. Member hech54's Avatar
    Aside from the other comments....I find it hard to believe that you would think
    that any DVD manufacturer would consider that as a selling feature....OR even
    consider listing it in the product specs if it does happen to do the same as you are asking.
    It's a one-in-a-million shot that someone would need or even inquire about such a feature.
  6. I'm a Poll Super Moderator johns0's Avatar
    Just get a dvd player that resumes from the point where you turn it off,lots of them do that anyways.
    Ben Johnson-I didnt take any stereos!
  1. update dvdplayer help
    By samben in forum Newbie / General discussions
    Last Post: 30th Nov 2006, 10:58
  2. Weird pause-play-pause thing in my mpg's?
    By NukeyDoo in forum Newbie / General discussions
    Last Post: 28th Sep 2005, 13:51
  3. Slide show with infinite pause wont't pause
    By valli in forum Authoring (DVD)
    Last Post: 8th Mar 2004, 10:21
  4. DivX DVDPlayer??
    By JAB in forum DVD & Blu-ray Players
    Last Post: 2nd Oct 2001, 03:41
About   Advertise   Forum   RSS Feeds   Statistics   Tools
