    I've got an issue with Media Player Classic playing .mts files. I get the video fine but no audio playback. These videos play back ok in VLC (although video playback seems a little jumpy due to spec of this machine i'm on) with the sound fine. I've had no issues with any other file types, just these .mts files that dont play audio.
    Any help would be much appreciated.
    To give you guys more info here is what Media Info says about the source file:
    General
    Complete name : D:\Adobe Prem Captures\STREAM\00050.MTS
    Format : BDAV
    Format/Info : BluRay Video
    File size : 774 MiB
    Duration : 23mn 40s
    Overall bit rate : 4 572 Kbps
    Maximum Overall bit rate : 18.0 Mbps
    Video
    Menu ID : 1 (0x1)
    Format : AVC
    Format profile : Main@L4.0
    Format settings, CABAC : Yes
    Format settings, ReFrames : 2 frames
    Duration : 23mn 40s
    Bit rate : 3 934 Kbps
    Width : 1 440 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16/9
    Frame rate : 25.000 fps
    Resolution : 24 bits
    Colorimetry : 4:2:0
    Scan type : Interlaced
    Scan order : Top Field First
    Bits/(Pixel*Frame) : 0.101
    Stream size : 666 MiB (86%)
    Audio
    Menu ID : 1 (0x1)
    Format : AC-3
    Format/Info : Audio Coding 3
    Duration : 23mn 40s
    Bit rate mode : Constant
    Bit rate : 448 Kbps
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Surround: L R, LFE
    Sampling rate : 48.0 KHz
    Video delay : -80ms
    Stream size : 75.8 MiB (10%)
    Cheers for any help
    Have you enabled ac3 decoding in mpc? under view->options->internal filters->transform filters.
    Or use ac3filter.
    Cheers Baldrick!
    Knew it would be something simple!
  1. Media Player Classic No Sound
    By jrank001 in forum Software Playing
    Last Post: 15th Feb 2010, 17:54
  2. Playback of MTS files (Canon HF series) using WesternDigitalHD Media Player
    By frmsuv2van in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 22nd Dec 2009, 01:29
  3. Media Player Classic audio playback problem
    By qpskfec in forum Software Playing
    Last Post: 3rd Dec 2008, 14:09
  4. Media Player Classic - Deinterlacing DVB playback?
    By katykaty in forum Newbie / General discussions
    Last Post: 18th Dec 2007, 11:26
  5. Media Player Classic Video Playback Problem
    By CybermatriX in forum Software Playing
    Last Post: 1st Apr 2006, 04:06
VSO Software ConvertXtoDVD lets you convert any video like AVI,MKV to DVD easily. More info or download trial!
About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
