I am getting to the point where I am losing my sanity over this. So please if anyone knows a simple solution or one that works please let me know.
What I am doing,
I have some HDTV rips that I want to watch on my Toshiba HD-30 HD-DVD player, I am unemployed and have not had a chance to upgrade to Blu Ray yet so I am stuck with this out-of-date player. Anyways what I want is a way to burn movies in HD that my player will read but putting them onto normal DVD +R media. I am willing to accept some loss of quality and already de-mux the audio and re-encoded it to MP3 320 kbps to reduce file size and I managed to get the files on my PC down to below 3 and a half Gb so I know they will fit onto a DVD, but if I try using NERO it DOWN converts to SD DVD and that is not what I want.
I also have a divx certified DVD upconverter but it does a terrible job of upconverting and the HD-DVD player won't play divx movies so I am stuck trying to get HD-DVD compliant video streams onto my DVD +r media, please any help would be greatly appreciated.
The video files I have are all MPEG4 h.264 encodes. I used software to extract the audio from the video, down mixed it from the uncompressed PCM to MP3 at 320 kbps bitrate and re-muxed the audio/video together and managed to get decent file sizes and everything looks great on my PC. All the video is in 1280 x 720 at 30 FPS, well 29-whatever it is, and the video is great quality, well better than when I converted them to SD and let my player upconvert them.
I have Nero 7 Ultra Edition, Sony Vegas 8 and Win AVI 6 among other programs but most of the ones I have are for doing PC type video and so far nothing allows me to come close to burning HD-DVD, I have a couple that allow HD-DVD data disc but that doesn't seam to work.
is that the only way to do it? Man I was hoping there would be an easier route. Thanks for the reply, looks like I got my work cut out for me.
The problem is that now that HD DVD is basically dead as a format for playback, no-one is investing any time or effort into software for it. Nothing new will offer authoring for it.
However if you are patient someone else may offer an alternate suggestion.
When you say that your files are HDTV rips, are they captured from over the air broadcasts? If so, they are MPEG-2 encodes and not H.264. Ulead Movie Factory 6 can author over the air captures into HD-DVD's that are burned on DVD-/+R. Your limitation is that you have to cut the movie file into 45 minutes chunks.
Some basic HD-DVD output may be possible with multiAVCHD after reencoding the source to fit some specs.
Laugh and the world will laugh with you. Cry and you will be alone
DVD memories - the early days!
By lordsmurf in forum MediaReplies: 5Last Post: 14th Jan 2009, 23:06 -
DVD playing for 4 days!
By Kargo in forum DVD & Blu-ray PlayersReplies: 4Last Post: 27th Jun 2007, 02:55 -
How good r DL DVD media these days???
By tpham in forum MediaReplies: 5Last Post: 24th Apr 2006, 12:32 -
which dvd burner to get now days
By dmb23 in forum DVD RippingReplies: 3Last Post: 20th Sep 2004, 21:40 -
My Newbie DVD Exp after 30 Days
By in7ruder in forum DVD RippingReplies: 7Last Post: 24th Jul 2003, 06:29
