My DVD plays on my PC using MPC-HC by open directory. It's not taking it in my Philips DVP3140. On the player itself, I get error. On my TV, I get bad disc. 3 or 4 of my discs was like that. I burned it using ConvertXtoDVD. I have Vista Home. Nero is failing to burn, or I could have had this to play. What should I do? How do I fix it?
possibly bad or low quality dvdr blanks. try to get some verbatim dvd-r or taiyo yuden dvd-r.
I don't know when I can get more. I have Memorex dvd+r
convertx usually does a decent job, so i wouldn't think it was the problem. that pretty much points to the discs. next time try dvd-r rather than +r as they play in more standalones.
so i can't watch anything on my player?
Of course you can, why would you think you can't?Originally Posted by rocky12
You've been given 2 suggestions on how to accomplish this:
1. Use ImgBurn to burn DVDs;
2. Use good quality DVDs, like Verbatim or TY. Any other brand/dye of DVD will be inconsistent at best (i.e. some burn and play OK, some don't).
DVD players are much more particular about burned DVDs than the drive in your computer.
If you aren't able to get new discs, at least burn your next ones with ImgBurn. It's all I've ever used, and I've even had decent (i.e. watchable) burns with lesser-quality discs. Nothing I'd be archiving, but suitable for something that's going to only be viewed a few times. But if you are burning stuff you want to hang on to for a while, definitely step up and get good media.
Hope that helps.
DVD plays, won't rip (now rips with CDRoller, won't import to TMPGEnc)
By koberulz in forum DVD RippingReplies: 14Last Post: 4th Dec 2011, 09:42 -
mp3 plays on Windows Media Player but won't play last minute in Sound Forge
By wetcamelfood in forum AudioReplies: 2Last Post: 1st Dec 2010, 15:47 -
ripped DVD plays, but won't burn
By Yes, me in forum MacReplies: 7Last Post: 3rd Sep 2009, 03:58 -
DVD plays fine on my TV but won't allow editing at all (11/15 deadline)
By Salva Veritate in forum Authoring (DVD)Replies: 14Last Post: 19th Nov 2007, 12:01 -
DVD (ISO) Plays Fine on PC, Won't Play on Standalone
By MoneyAddyct in forum Newbie / General discussionsReplies: 1Last Post: 17th Jul 2007, 21:15
