Hi people,
Bought this DVD player today, of course right away tested if it can play Divx mkv container by any chance, no it can't.
Next thing was to test HD DivX and HD wmv, didn't work. Hope because of my old TV (crt). Can anyone test HD DivX and HD wmv files on this DVD player with HD TV.
Update:
Windows Media Video (WMV) compatibility:
WMV content can be encoded by using Windows Media Encoder.
This player is compatible with WMV9 files that are encoded by using the Windows Media Encoder 9, 10, or 11 Series, with .wmv as an extension.
Compatible with size under 720x480 pixels.
Advanced Profile is not supported.
DRM-protected video files will not play in this player.
thanks
V.
PS.
MPEG2 files from hard drive (via USB) play very smooth compare to choppy Philips USB playback.
Thread: Pioneer DV-420V
None of this class player plays any kind of HD media. Top resolution is usually between 720x576 and 800x600.
You need to move up to the ~$200+ class with the Sima Designs 8xxx series chipset.
http://www.videohelp.com/dvdplayers?...Submit2=SearchRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Any idea what chipset is in Pioneer DV-420V?
Was not able to find any info on it.
Vasilii
No but this class of player only has SD decode capability + realtime upscale chip for 720x576 to 720p/1080i/1080p.Originally Posted by VasiliiRecommends: Kiva.org - Loans that change lives.
The 410 uses a MediaTek, I'd guess the 420 uses the same.
The number of DVD players that can play anything in MKV containers is probably less than 5 and I don't think Pioneer makes any of them.
Pioneer DV-420V-K long filenames
By umniy2000 in forum DVD & Blu-ray PlayersReplies: 21Last Post: 7th Apr 2010, 15:20 -
Pioneer DV-420V-K settings
By umniy2000 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 26th Dec 2009, 19:55 -
Regio free code for Pioneer DV-420v
By baraburu in forum DVD & Blu-ray PlayersReplies: 2Last Post: 15th Jul 2009, 23:48 -
Regio free Pioneer DV-420V-K
By baraburu in forum DVD & Blu-ray PlayersReplies: 1Last Post: 15th Jul 2009, 23:46 -
Pioneer DVR-104 (A04) and Pioneer 533k Player - NO SOUND!
By JackoFluent in forum DVD & Blu-ray WritersReplies: 1Last Post: 13th Jun 2002, 02:40
