When I am attempting to convert multiple clips from AVI to DV, FFMpegx converts the first one then fails all the rest. Restarting the program is the only remedy I have found.
Anyone know what is going on, and/or how to fix it?
bam
Thread: AVI to DV fails after one.
You need to re-set the conversion settings (the DV preset) for each file, after opening a new source file. Tedious, but that is the way the program currently operates. Could that be it?
Or try EmmGunn's Quick Batcher for batch processing with ffmpegX.
Thank you for the reply Case!
Yes, you are correct. When I import a new mp4 it changes the aspect ratios of the DV preset.
However, I would like to keep the same aspect ratio and resolution as I shot in 720p. When I attempt to manually set the video size to match 1280x720 it fails.
There is something wrong with this failure. I am guessing.
Thoughts?
DV (NTSC) is always 720x480, for both 4:3 and 16:9.
1280x720 is not a valid DV resolution. If you want to keep it 1280x720, then you shouldn't convert to DV.
.avi to mpeg 2 fails every time.....
By phillyman in forum Video ConversionReplies: 5Last Post: 6th May 2010, 14:44 -
dumphd-0.61 fails
By fjmr in forum Blu-ray RippingReplies: 3Last Post: 5th Aug 2009, 18:24 -
avi: alright with mediaplayer, virtualdub fails
By engel in forum Software PlayingReplies: 14Last Post: 11th Aug 2008, 03:59 -
burns fails. help
By dymx in forum Newbie / General discussionsReplies: 8Last Post: 18th Jun 2008, 13:54 -
encoding from WMV to .avi usin "decode with QT", audio fails
By fury420 in forum ffmpegX general discussionReplies: 3Last Post: 18th Jun 2007, 00:21
Statistics
Newest guides
Latest tool updates
New media comments
