VideoHelp.com Forum
    Since the digital conversion the only TV channels I can get are the virtual ones, eg 8-1 8-2 etc. My DVR does not accept these channels. Do I need a new DVR or am I missing something here? The Accurian DVR I have is fitted with both HDD and CD recording devices and any new one would have to be configured like that. Any ideas from you experts?
  2. Member edDV's Avatar
    Does the Accurian DVR have a digital ATSC tuner?
    If it does, set up your antenna and scan. You should get the available digital channels.
    As of the analog shutdown, there is no longer a Ch8.
    If your DVR lacks a digital tuner, you will need to use an ATSC converter box.
    http://www.kiva.org/about
    I think the problem is simply my DVR not having a digital tuner. It looks like I need to research available products to see if I can find what I need. That might not be easy. Very few stand alone recorders have both an HDD and CD drive.
  4. Member edDV's Avatar
    As a workaround, you can try an ATSC SD Coupon convert box. Two of interest,
    Channel Master CM-7000 has S-Video out + audio
    EchoStar/Dish DTV-PAL has a programmable timer for channel switch.
  1. Is there a DVD Recorder that can record Subtitles from HD channels?
    By MounaLafi in forum DVD & Blu-ray Recorders
    Last Post: 14th Mar 2011, 15:32
  2. Capture and Record US Cable Channels in full HD?
    By onesikgypo in forum DVB / HDTV
    Last Post: 2nd Jun 2010, 22:42
  3. Replies: 5
    Last Post: 1st Dec 2009, 17:46
  4. PVR will not record certain channels
    By sundown in forum DVD & Blu-ray Recorders
    Last Post: 13th Apr 2009, 04:56
  5. DVD record multiple channels?
    By bobful in forum Newbie / General discussions
    Last Post: 22nd Jan 2009, 19:10
