I have Vista Basic x64 and use Windows Media Player to play back DVD's with the Cineplayer DVD decoder installed.
WMP plays back my AVI's just fine with good audio but it's a little low when playing back DVD's. I'm wondring if that's a limitation of the codec? I also have WinDVD and use it occasionally. It plays back the audio on DVD's just fine. Could WinDVD being interfering in anyway with WMP playback?
Thread: Low auido on WMP with DVD codec
ac3 audio might sound a bit low using some audio decoders. I would try use ac3filter to decode the dvd audio instead.
I already have AC3 installed!
You might have it installed, but you're not using it to its fullest.Originally Posted by janlafata
Somewhere in the filter configuration is a way to custom mix the channels and
increase the volume, if necessary.
Selecting the preferred DVD decoder/codec for WMP under Vista x64
By Dark Alpha in forum Software PlayingReplies: 10Last Post: 17th Jan 2009, 22:05 -
which codec to download to play DVD on wmp 10 ?
By perfection in forum Newbie / General discussionsReplies: 3Last Post: 2nd Oct 2007, 01:28 -
Problem with DVD audio in WMP when Klite Codec Pack installed
By needhelpdvd in forum Software PlayingReplies: 4Last Post: 22nd Oct 2006, 12:34 -
WMP tries to downoad codec even though codec is installed!
By LisaB in forum Software PlayingReplies: 0Last Post: 7th May 2003, 16:13 -
WMP codec uninstall
By mysticgohan17 in forum Software PlayingReplies: 1Last Post: 7th Oct 2002, 23:31
Statistics
Newest guides
Latest tool updates
New media comments
