When I play mkv files I receive no sound in wmp or media player classic but yet in vlc probably because it uses it own codecs.
I have halli media splitter install and ffdshow but no luck. I am sure that it is probably something in ffdshow. Any suggestions?
Obviously some codec is missing or it is not activated on ffdshow.
Re-install latest ffdshow and do a reset. It might work. If not, you have to find which codec your mkv has and set it manually for playback to ffdshow.
Check your file with mediainfo to find out the audio codec then you can tell if it is installed activated. Most mkv files I've seen have aac audio. Could be you need to enable aac and you might also need to install an aac parser/splitter
Donadagohvi (Cherokee for "Until we meet again")
My Video Tools :: Free Security Software :: Ubuntu Antivirus Rescue CD
Playing flac. files using ffdshow and Media Player Classic
By Cunhambebe in forum Newbie / General discussionsReplies: 13Last Post: 5th Jul 2011, 04:32 -
Glitchy MKV files in Media Player Classic Home Cinema
By djdust in forum Newbie / General discussionsReplies: 1Last Post: 23rd Feb 2011, 16:45 -
Media player Classic won't let me "navigate" using mkv files
By FatalX in forum Software PlayingReplies: 0Last Post: 20th Jul 2010, 20:51 -
'Combing' effect when playing VOB files with Media Player Classic
By djdust in forum Software PlayingReplies: 1Last Post: 16th Oct 2008, 20:23 -
Problem playing wmv files in Windows Media Player and Media Player Classic.
By rayden54 in forum Software PlayingReplies: 4Last Post: 1st Aug 2008, 22:49
Statistics
Newest guides
Latest tool updates
New media comments
