VideoHelp.com Forum
  1. I've got my HTPC hooked up to my at the moment via a DVI to HDMI cable. Unfortunately, there is no separate audio input on the TV for the HDMI. I really don't wat to have to send the audio to a separate set of speakers, so I was looking for another alternative. When I have it connected VGA, it looks okay, but there is a bit of ghosting, icons were hard to read, and the image often lagged a bit. I found this: http://sewelldirect.com/dvivideoadapter.asp
    Is this going to give me the same quality as VGA because it's just pulling the analog signal from the DVI port?
    This plan is so bad, it must be one of ours.
    That adapter will only work with specific ATI graphics cards that output component at the DVI port (this is not a standard feature of DVI). You need to verify if your graphics cards is one of them or all you'll have is a paperweight.
    Ghosting over VGA indicates a poor cable. How long is the cable? What resolution are you running at?
  1. dvi vs component cables
    By consumer567 in forum Newbie / General discussions
    Last Post: 29th Dec 2009, 16:06
  2. tv out(dvi to component) problem
    By tseizaL in forum DVB / HDTV
    Last Post: 25th Dec 2009, 08:22
  3. Composite to HDMI/DVI/component Conversion
    By Gromit137 in forum DVB / HDTV
    Last Post: 30th Oct 2008, 11:10
  4. DVI/Component cable
    By ajcstr in forum DVB / HDTV
    Last Post: 16th Oct 2008, 05:25
  5. Using a DVI to Component adapter?
    By videonewbie69 in forum DVB / HDTV
    Last Post: 2nd Aug 2007, 05:17
