Hi
I am looking for a freeware to split avi files by number of segments (ie) if I mention 5, the software should split the video file into 5 segments (of course cut each segment on key frames).
I see Yamb has this option but it works only with mp4 mov 3gp etc and not avi.
I currently use VirtualDub for cutting video files but here I need to manually select the segments. Is there any freeware which can do this?
Thanks for the help.
Thank you very much. I never knew this existed in virtualdub. Thanks again.
Just curious. What abt split by duration where if I specify 20min (assume video file 100min), i ll get 5 segments.
Yamb has this option for mp4. Any freeware for the above thing in avi? -
There is an option in the dialog box to split by max #frames per segment. So if you know the fps, you can essentially do the same thing. You can use mediainfo or vdub's file information to find out the fps
e.g. 23.976 fps footage x 60 seconds/minute x 20minutes = 28771 frames
Don't forget to set the video & audio to "direct stream copy"
Vdub script / tool etc - split large file into 10 min segments? (auto)
By Jynks in forum Newbie / General discussionsReplies: 0Last Post: 17th Apr 2010, 06:19 -
tool to split MP4 into 10 min segments for youtube?
By sdsumike619 in forum EditingReplies: 6Last Post: 31st May 2009, 15:18 -
Split Mpeg or convert to AVI then split. What to do?
By oldfart13 in forum Video ConversionReplies: 4Last Post: 24th Mar 2008, 00:00 -
How To Split Single DV AVI file into Multiple DV AVI files using Time Stamp
By insysnet in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 23rd Aug 2007, 12:49 -
appending avi segments w/virtualdubmod
By burgkev in forum Newbie / General discussionsReplies: 2Last Post: 13th Jun 2007, 13:14
