VideoHelp.com Forum
Results 1 to 20 of 20
  1. Mod Neophyte Super Moderator redwudz's Avatar
    I picked up this netbook a few days ago from NewEgg, about $260US. http://www.newegg.com/Product/Produc...82E16834220441
    So far, I really like it. It's very small, about 9" X 7" and 2.5lbs. It has a very large 160GB HDD and comes with XP SP3. It also includes a 3MP camera and three USB ports. No floppy or CD/DVD drive, but they wouldn't fit anyway. If you need more storage, it will run a 2.5" external drive, though your battery life will suffer. It also has a MMC/SD(SDHC) card reader, a VGA port and a 10/100 LAN port, along with the WiFi.
    It does have great battery life in the stock configuration, about 5 hours. It's perfect for long airline flights or just to carry around to WiFi hotspots. I did upgrade the RAM to two GB. (~$25US) It comes with one GB. I may try Vista on it later. Some users have done this and it will run Aero, though the Atom 1.6Ghz CPU is somewhat minimal for that.
    It's basically a shrunken laptop. I can even manage to touch type on it if I'm careful. It has a nice touchpad and since the KB is small, your fingers don't hit it too often when typing. I prefer a mouse, so I added a Verbatim radio mouse that has a tiny transceiver, about a 1/4" high when plugged into the PC, so you can leave it plugged in all the time. The screen is small, 1024 X 600 (Widescreen) but very legible and seems bright enough except in full sun. The audio is decent too, but most will opt for ear buds for watching video. Since the screen is small, even low quality video looks good.
    It come with the typical 'crapware' installed, but easy to remove this and put in the programs of your choice. The only real problem I ran into was that the stock XP WiFi software wasn't up to WPA2 AES encryption with the Atheros WiFi chip and would lose the connection quickly, even though I had a strong signal. But on a Asus eee forum, (http://forum.eeeuser.com/) I found I could replace the XP client with the Atheros Client Utility 7.6.1.149, and now it does fine with my router's WPA2-PSK [AES] encryption.
    I did find the black shiny top of the PC is a fingerprint magnet, so the white version may be a better choice for some, if you can find it.
    Specifications from NewEgg:
    General
    Brand ASUS
    Series Eee PC
    Model EPC900HA-BLK006X
    Color Shiny Black
    Operating System
    OS Provided Windows XP Home
    Processor
    CPU Type Intel Atom
    CPU Speed N270(1.60GHz)
    CPU FSB 533MHz
    CPU L2 Cache 512KB
    Display
    Screen Size 8.9"
    Widescreen Display Yes
    Display Type WSVGA
    Max Resolution 1024 x 600
    Graphics
    Graphics Processor Integrated Graphics
    Video Memory Shared system memory
    Memory
    Memory 1GB
    Hard Drive
    HDD 160GB
    Dimension & Weight
    Dimension 8.86" x 6.69" x 0.79-1.33"
    Weight 2.49 lbs.
    Feature
    Feature Easy to Learn, Work, and Play
    Travel light, weighting only 2.49lbs
    Wireless connectivity
    Connect with friend with built-in Camera
    10GB Internet Storage
    XP Home, MS Works, and Windows Live preloaded
    And Wide Touchpad for comfort and convenient
    Glossy IMR Fine Ebony color for elegant look
    ZBD Guaranteed for best quality LCD
    Protect your investment with sleeve case
    Netbook Camera
    Camera Type Built-in
    Camera Pixels 0.3 Megapixel
    Communications
    LAN 10/100Mbps
    WLAN 802.11b/g Wireless LAN
    Expansion / Connectivity
    USB 3
    Video Ports 1 x VGA
    Audio Ports 1 x Microphone jack; 1 x Headphone jack
    Audio
    Audio Hi-Definition Audio CODEC
    Internal Microphone
    Speaker Built-in stereo speakers
    Input Device
    Touchpad Yes
    Keyboard Standard
    Card Reader
    Card Reader MMC/SD(SDHC)
    Power
    AC Adapter 12V, 36W, 100-240V AC, 50-60Hz universal
    Battery
    Battery 4-cell lithium ion
    Battery Life 5.3 hours
    Software
    Software MS Works, MS Live, Sun Star Office
    Manufacturer Warranty
    Labor 1 year limited
    Parts 1 year limited
    In conclusion, I think it's a good value for the price and should be handy when you don't want to drag around a full size laptop. And it would be a great kids computer. It's probably not much of a game computer, but it's a whole lot cheaper than one that is.
  2. Member classfour's Avatar
    I'd bought the 1000HA back in February, and am enjoying the long battery life, fast loading, and light weight of the thing. It's pretty much the same machine except for the 10 inch screen. The right shift key is my only complaint, as I haven't quite gotten used to it. I have upped the RAM to 2GB, and bought a Plextor 608 portable DVD burner for it. Tested it watching DVDs with the included intervideo player - it never skipped a beat.
    ;/ l ,[____], Its a Jeep thing,
    l---L---o||||||o- you wouldn't understand.
    (.)_) (.)_)-----)_) "Only In A Jeep"
  3. Member racer-x's Avatar
    I bought one of these for my son as a birthday present. He'll be getting it in a few weeks, I'm sure he will love it. I like it myself, but the screen and keyboard are too small for my tastes.
    I already removed all the pre-installed crap and made a restore image on an external HDD. I'm sure I'll be needing soner or later..........
    There is no such thing as "Idiot-Proof".........a good Idiot will get around that every time.
  4. Member MJA's Avatar
    why you didn't get the 10" Lenovo S10,or the Dell Mini 10v for $299
    even the ASUS Eee PC EPC1000HA is selling for $299 at ZZF
  5. Member usta's Avatar
    Nice review redwudz!
    I'm waiting for Lenovo S12 that is expected to arrive in August. This netbook will combine Intel Atom N270 and Nvidia’s GeForce 9400 graphics. Nvidia promises full HD experience with combo. I'd like to see it connected to TV via HDMI and play 1080p movies.
    I think Asus, Dell and others will follow shortly with their models.
  6. contrarian rallynavvie's Avatar
    A coworker got one of Dell's for $200 without OS or HDD. He later got an SSD for his on sale. He is using the netbook build of Ubuntu and I really like how he has it set up. I am now considering getting one for my dad to replace his junky Latitude since all he does is internet, email, and some office applications.
    I was considering one to replace my Vaio SZ. I don't travel as much anymore so compact size isn't as important to me so I think I may instead get one of the new 15" MacBook Pros now that they have the new battery and dual-video option.
    FB-DIMM are the real cause of global warming
    Nice review, and nice price! A few months ago I was looking to get a laptop or netbook, just to have a portable computer for basic email/web/etc. Ended up going with a refurbed T43 for about the same price as that netbook is now. Might have more seriously considered the netbook if it had been that low a few months ago.
  8. Member MJA's Avatar
    anything over 10" isn't a netbook
  9. Mod Neophyte Super Moderator redwudz's Avatar
    I primarily wanted small. I already have a couple of notebooks, but they're a pain to use on a airplane and the battery life is too short. This netbook is also handy for the library or in a internet café for a quick check of your email. When they added the 160GB HDD, I was sold.
    There are also lots of mods and tips on the Asus eee forum if you want to do a bit of 'fine tuning'.
  10. DVD Ninja budz's Avatar
    As always redwudz excellent review. Now another toy I'm gonna wanna buy!
  11. Member usta's Avatar
    In the beginning 7 inch netbooks were the standard.
    1 year ago 9 inch was the standard.
    Half a year ago the 10 inch netbook became the standard.
    Now, the manufacturers are trying to push 11 or 12 inch to become the new standard.
    Where is this going/
  12. Hello Ladies stiltman's Avatar
    More options for the person purchasing netbook/laptops
    Originally Posted by jagabo
  13. Member Super Warrior's Avatar
    Good choice! The 900HA was my first netbook, when i got tired of lugging my large 15" dell Vostro 1000 laptop around. All i require is a solid, entry-level comp for my needs the 900HA was almost perfect.
    The only flaw was the screen. Since this was going to function as my only comp, the 9" screen was just a tad TOO small for comfortable 24/7 use.
    I then moved up to a 1000HA(white) which is pretty much the exact same comp, only now with a 10" screen! The large comfortable keyboard was nice too, but the star here was the display. If you've never used a 10" version, you'd be surprised at what an amazing difference that extra inch makes!!
    IMO 10" is the perfect netbook size, compact yet still roomy and comfortable on the eyes.
    Also heads up to you guys on a Great deal, MSI Wind 10" for $300 w/free shipping at newegg.com. I'd definitely buy this if i didn't already have an ASUS 1000HA:
    http://www.newegg.com/Product/Produc...82E16834152092
  14. Member Super Warrior's Avatar
    Stay away from the Dell netbooks! Last i heard those damn things, while nice, had one crucial flaw: Ram memory integrated with no available slot, this means you're stuck with 1GB forever!
    This is crap since the majority of netbooks out there have the option to be upgraded from 1GB to 2GB. Guys make sure that whatever netbook you buy can be upgraded in the future!
    I can't imagine ever going with a 7" display for ANY amount of time. Oh yes people, there IS such a thing as being TOO compact!!
    As it is the 9" was the bare minimum i'd be willing to go with, and even that was still a tad too small for me.
    ASUS has since then phased out the 7" line. Which is good. The smallest netbook size should stay at 9".
    Semi-Agreed.
    However, keep in mind that on many 10" netbooks, the screen does NOT fill the lid completely. You could easily fit at least 1" more on my 1000HA and still have room on the sides to spare.
    Thus it would be acceptable if 11" netbooks came out, so long as they were no larger in anyway than current 10" models.
  15. Member SingSing's Avatar
    I am convinced that a Ipod touch is a better web-browser than these Netbooks.
  16. The Old One SatStorm's Avatar
    Actually, you can do your job with 5" (4:3) prety well... I worked for a while a PDA that way, so I know.
    Regarding "netbooks", actually I believe that they have to be lightweight and with small displays. 7,8 or 9", but not more.
    IMO, from 10" and up, you have a laptop, not a netbook. Except if we lebel "netbook" all the Intel Atom based solutions. Then yes, we can even have 15" netbooks that way...
  17. Mod Neophyte Super Moderator redwudz's Avatar
    I don't have any problem with the small screen/display. It's going to be used more for movie viewing and email and the screen is fine for that. The compact footprint is great for portability and that was important. I could have got one with a larger display, but it's what I wanted for my purposes and it does what I wanted.
    I would agree that you should see these type of NetBooks in person and see if it's what you want. But I have no interest in a tiny display like a cell phone. 1024 X 600 seems perfect for most movies. If I wanted bigger, then I have a couple of regular laptops. But their batteries don't last 5 hours.
  18. The Old One SatStorm's Avatar
    To tell you the truth, I use my Nokia N82 cellphone to watch movies on the go... It lasts 4 -5 hours.
    I had an Archos before. Better display, more time, a true portable media player. But I kept forgeting to take it with me...
    I never forget my phone, so I end up using it
    I have a 12" laptop (Acer 6290) for portable computing. It lasts 3,5 hours.
    But I know that a netbook has uses. Also a tablet PC. It all has to do with your current needs.
  19. Mod Neophyte Super Moderator redwudz's Avatar
    Since I got a bit older and use tri-focals, the small displays don't work too well anymore.
  20. Member Super Warrior's Avatar
    Well all netbooks are, essentially just tiny formfactor laptops. My 1000HA, aside from understandable stuff like internal disc drive, is otherwise every bit as good as my last full sized basic laptop was.
    So as long as it has a SMALL formfactor, it could be considered a netbook. Its all in the size.
  1. Replies: 8
    Last Post: 10th Dec 2010, 22:55
  2. Best Netbook available at BestBuy
    By ryangarfield in forum Computer
    Last Post: 1st Jun 2010, 22:34
  3. Do you own a netbook?
    By yoda313 in forum Polls
    Last Post: 18th Apr 2009, 23:25
  4. ASUS My Cinema-U3000 Mini Problem
    By TheLarch in forum Capturing
    Last Post: 8th Feb 2008, 06:16
  5. Mini Review - Elecard Converter Studio AVCHD Edition
    By Soopafresh in forum Video Conversion
    Last Post: 5th Feb 2008, 11:38
