VideoHelp.com Forum
Results 1 to 9 of 9
    Hi, I just bought some dvds from Amazon.com and I think they're region 2, PowerDVD couldn't play them and it gives me the Region Code error. so how can I watch them ? can anyone suggest me a program or a way to play them or change the region of them ?
    Thanks in Advance
    Rip the dvd to your computer
    Use IFOEdit to edit VIDEO_TS.IFO
    there is a option in IFOEdit to set the DVD Region Free
    hope this helps
  3. Always Watching guns1inger's Avatar
    You have to either change the firmware in your DVD drive so it is region free, or you have to rip the DVDs and make a copy that is region free.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
    Or use
    dvd43, free but may not work on all systems
    anydvd, the best but not free then.
    ( I guess you just want to play them on your computer...and not a standalone dvd player)
    Or install the free VLC media player on your PC. It ignores region codes on DVD. No ripping or other software will be required. It will simply play your DVD.
    Thank you for the replies. I always use VLC but it won't start the dvds. I just cut change the current region with DVD Genie and play them with WMP. now I want to watch them on my DVD Player. my dvd player is not Region Free. and I know there is no code to make it Region Free. any easy-simple way to break the region and convert these dvds to DVD5 to play them on DVD Player ?
    Yes.
    1) Rip with free DVDFab HD Decrypter.
    2) Shrink to DVD-5 size with free DVD Shrink.
    3) Burn with free ImgBurn.
    No cost to you for any of those.
  8. Always Watching guns1inger's Avatar
    However Region 2 covers Japan (NTSC) and the UK (PAL). If your player cannot play both formats you may still find it refuses to play the discs after removing the region code simply because it cannot play the format of the discs. In that case you are in for a lot of work, and should possibly consider getting a better DVD player if you are going to import discs.
    Hi. thanks for the replies
    I just downloaded DVDFab 6.0.1.0 but when i click on Start button nothing happens. seems the programs doesn't work. can anyone help ?
    With 5.2.3 version it works
  1. LG BD660 DVD and BD Region unlock pls help..
    By hochimin in forum DVD & Blu-ray Players
    Last Post: 27th Dec 2011, 23:42
  2. unlock region code Samsung DVD-VR357?
    By amyfj in forum DVD & Blu-ray Players
    Last Post: 1st May 2011, 08:19
  3. Unlock region code for Panasonic DVD-S1
    By Jurgs in forum User guides
    Last Post: 4th Jan 2011, 22:17
  4. Help ! Panasonic BD-60 UNLOCK DVD region code (Region 1)
    By aexp in forum DVD & Blu-ray Players
    Last Post: 3rd Sep 2009, 10:24
  5. region-free unlock help (dvd player not on list)
    By pbure0110 in forum DVD & Blu-ray Players
    Last Post: 15th Jul 2007, 14:50
