I use Gom player mostly (its my favorite player cuz it has the best fast-forward feature for avi's and mkv's) but when i try to open mkv's made with mkvmerge newer than version 2.60, i get no video & sound. VLC and mpcht play fine. I have the newest version of Gom. Any ideas?
I'm also a fan of GOM Player and use it as a primary player.
I can totally relate to this problem. VLC plays the same video just fine.
I've noticed that it has a problem to open MKV files that are made with mkvmerge 2.9.0.
Here are the details of a video file that GOM Player can't play, while VLC can (source Mediainfo):
Writing application : mkvmerge v2.9.0 ('Moanin'') built on May 22 2009 17:46:31
Writing library : libebml v0.7.7 + libmatroska v0.8.1
Video
Format : AVC
Format profile : High@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Muxing mode : Container profile=Unknown@4.0
Codec ID : V_MPEG4/ISO/AVC
Duration : 24mn 28s
Width : 960 pixels
Height : 540 pixels
Display aspect ratio : 16/9
Frame rate : 23.976 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Writing library : x264 core 67 r1145M d2e1e1c
Encoding settings : cabac=1 / ref=3 / deblock=1:-2:-2 / analyse=0x3:0x133 / me=umh / subme=9 / psy_rd=0.0:0.0 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=0 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0 / threads=3 / nr=0 / decimate=1 / mbaff=0 / bframes=2 / b_pyramid=0 / b_adapt=2 / b_bias=0 / direct=1 / wpredb=1 / keyint=240 / keyint_min=1 / scenecut=40 / rc=crf / crf=21.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=8 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00
Audio
Format : AAC
Format version : Version 4
Format profile : LC
Format settings, SBR : No
Codec ID : A_AAC
Duration : 24mn 30s
Channel(s) : 2 channels
Channel positions : L R
Sampling rate : 48.0 KHz
Resolution : 16 bits
Text
Format : ASS
Codec ID : S_TEXT/ASS
Codec ID/Info : Advanced Sub Station Alpha
Oh, well... seems like a puzzle.... anyways...i just use mkvmerge to convert all mkvs back to version 2.60, till i figure it out.
Thanks for reply.
Cheers!
Cannot play avi file with vlc player/divx player or GOM Media Player (GAVC)
By texasdontholdem in forum Software PlayingReplies: 6Last Post: 20th Mar 2012, 10:22 -
new abbrev, GOM = GOM Player ?
By lordsmurf in forum FeedbackReplies: 1Last Post: 1st Apr 2009, 15:00 -
Slight problem with GOM Player
By jonghyunchung in forum Software PlayingReplies: 1Last Post: 22nd Oct 2008, 02:04 -
how to use gom player for screen capture
By shashgo in forum Newbie / General discussionsReplies: 1Last Post: 9th Aug 2008, 21:33 -
GOM Player problem
By Traveller in forum Software PlayingReplies: 2Last Post: 21st Oct 2007, 19:26
Statistics
Newest guides
Latest tool updates
New media comments
