Hey guys, I'd appreciate it if you smart ones could give me a hand here :P Recording in HD is as simple as buying a Blackmagic Intensity Pro, I know, but how do I go abouts playing on my TV (so Xbox outputting to TV) and also outputting to the Intensity Pro?
So at the moment I'm recording in SD. I have my Xbox outputting through the scart lead into a scart box, that scart box goes into the TV, hence allowing me to play on the TV. Also, the scart box has "source output" on which is basically composite output. That leads into my PC where I record in SD.
Anyhow, my TV has no sort of HD output according to my manual. So basically my only option is to output the Xbox to the Intensity Pro. I need a set-up so I can do that AND play on my TV (in HD). What sort of hardware am I going to need for this? I'm thinking a box that I can plug the Xbox leads into which then outputs two HD signals. I think I've come across one of these before but it was WAY too expensive. Can anybody head me in the right direction please?
PS: I have a Samsung TV; Scart, VGA, HDMI, DVI, and Component inputs in terms of video.
Thanks for reading
EDIT: I think I'm looking for a splitter, right? Do I just need two HDMI cables and this gadget: http://www.tvcables.co.uk/cgi-bin/tv...ter-2-way.html, for it to work, yes? Is there a splitter like that which will also output composite? (I take it that's a downgrader and will cost lots).
Results 1 to 1 of 1
Capturecard for xbox 360 and record with PC
By ThePie69 in forum CapturingReplies: 6Last Post: 10th Aug 2011, 21:43 -
My DR-DX5 has the dreaded non-descript "loading" error.
By Cyrax9 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 19th Feb 2011, 20:38 -
how do you record xbox 360 gameplay while using microsofts xbox 360 vga ?
By rushinplaya in forum CapturingReplies: 18Last Post: 3rd Apr 2010, 06:19 -
Trying to find the best way to record Xbox 360 gameplay
By Zaz in forum CapturingReplies: 2Last Post: 2nd Dec 2009, 08:12 -
The BEST Way To Play & Record Xbox 360 Through Your PC?
By njosnavelin78 in forum CapturingReplies: 142Last Post: 25th Dec 2008, 14:43
