I have a srt-file who I guess is made for another version of the serie I want to watch. Because after the commercial break, the sub is out of synq.
So I just wonder; can I put in a delay from for instance 30 minutes of the episode, so the rest of the episode will be in synq.
Thank you in advance!
I have no idea if you can do that in Subtitle Creator, I would use Subtitle Workshop. The help file describes the procedure rather well.
In the beginning the Universe was created. This has made a lot of people very angry and been widely regarded as a bad move.
Thank you for your recommendation träskmannen. Subtitle Workshop seems to have more features, and it was very easy to work with. No need for help file
. And the job is done. Thank you again!
You can use Easy subtitles Synchronizer (ESS). Is more easier than other tools. Less clicks.
Download Easy subtitles Synchronizer from here: http://easysubs.no-ip.info/ess
Good Practices using Easy subtitles Synchronizer
For subtitles that do not require synchronization, load the file to ESS, repair them
(see Synchronization tools, repair) and finally save with a proper filename and encoding
type.
For subtitles that require synchronization, load the file to ESS, and try to
synchronize them using “Adjust” tool. If the tool ‘Adjust’ fail to synchronize, try the
“Manual Synch” tool. Finally repair them and save with a proper filename and encoding
type.
Video and subtitle/sound sync problems in SubtitleCreator
By ditz in forum SubtitleReplies: 2Last Post: 20th May 2011, 04:12 -
Subtitle delay jumping up & down.
By chiappa in forum SubtitleReplies: 0Last Post: 18th Jan 2011, 05:31 -
SubtitleCreator - converting srt to sup with delay
By michcio in forum SubtitleReplies: 0Last Post: 7th Nov 2009, 05:19 -
subtitle does not synchronize with the movie when using SubtitleCreator
By bimatquocgia in forum SubtitleReplies: 2Last Post: 7th Feb 2009, 10:10 -
How to take the timings from one subtitle and put them into another?
By acid_burn in forum SubtitleReplies: 0Last Post: 8th Jul 2007, 11:11
Statistics
Newest guides
Latest tool updates
New media comments
