hello
Just discovered and downloaded VOB2MPG 3.0.030
I want to backup my DVDs to mpg files so I can then have a library of DVD quality files that i can then convert to other formats using mediacoder or handbrake.
I would like to keep all the audio tracks or at least 2, the English language track and the director's commentary.
I did one test in IFO mode and selected the default audio from the audio stream drop down menu. When I played back the mpg file, it contained all the audio tracks. This isn't a problem, I was just wondering if this is the expected result. If i don't touch the audio stream setting, do i always get all the audio streams in the resulting mpg file?
Thread: VOB2MPG Multiple Audio Streams
If you leave the audio dropdown as is (i.e. DEFAULT) - the mpeg will contain all the audio streams. The default audio stream identified is the "first" audio stream and this is the one that most players will play.I did one test in IFO mode and selected the default audio from the audio stream drop down menu. When I played back the mpg file, it contained all the audio tracks. This isn't a problem, I was just wondering if this is the expected result. If i don't touch the audio stream setting, do i always get all the audio streams in the resulting mpg file?
If, however, you select an audio stream - all others are discarded.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Can Vob2MPG convert audio streams?
By ThejafF23 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 13th Dec 2011, 12:07 -
VOB2MPG multiple selective audio tracks
By hhhgamewmx7 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 11th Jul 2011, 03:49 -
Multiple Audio Streams (Avi)
By nycboriqua in forum EditingReplies: 5Last Post: 26th Sep 2010, 17:42 -
Play multiple streams in DVD (Merge multiple streams)
By sebastien91 in forum SubtitleReplies: 0Last Post: 25th Apr 2009, 18:44 -
multiple audio streams
By Tobberian in forum AudioReplies: 2Last Post: 14th Jul 2007, 12:54
Statistics
Newest guides
Latest tool updates
New media comments
