VideoHelp.com Forum
    Do they make DVD double layered media in -RW format? I have need of such a beast. I like to record movies off TV and edit out the commercials, but most movies w/commercials are over 2hrs long, and my resolution suffers because I have to record in LP mode due to the length. But by the time I edit out the commericals, we're usually down to under 2hrs. If I could record in SP mode with -RW, then edit and reburn onto -R, then my problem would be solved.
    Any suggestions would be appreciated. I'm not able to record directly to PC. That would have been the easiest fix.
    Nope.
  3. Member victoriabears's Avatar
    Get a dvd recorder with a hard drive, roughly edit out the commercials there, and transfer resulting shorter length to a dvd , or get a capture card for your PC.
    PAL/NTSC problem solver.
    USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS
  1. Replies: 8
    Last Post: 5th Feb 2011, 16:13
  2. Replies: 4
    Last Post: 17th Feb 2010, 17:21
  3. "flipper" to dual-layer DVD
    By Norm Strong in forum DVD Ripping
    Last Post: 2nd Jul 2009, 10:20
  4. "splitting" dual layer to 2 dvd+r?
    By tlinehan in forum Mac
    Last Post: 13th Jul 2008, 16:42
  5. Replies: 5
    Last Post: 25th May 2008, 12:16
